PoorManQ45 wrote:Nope.
Overbore it to ~5.0. Then go with ~15:1 pistons. And change all the subsequient parts that would need to be changed. Mill the heads. Increase the valve lift/duration.
As Rex has said, that will make some serious power.
PMQ, buddy, if I just give you a pat on the bottom & send you home you'll get mad. So allow me to echo DAEDALUS' sentiment and SUBSEQUENTLY outline the specific inaccuracies about your statement.
1) You can't BORE only to achieve that much of an increase in displacement. You must have a longer stroke, necessitating a different (custom) crank, rods, and probably a custom piston.
2) 15:1 cr? You must be joking, unless you have race gas at every pump where you travel, or you retard the timing to...oh...1 degree BTDC.
3) Then mill the heads to bring the valves even closer to the pistons?
4) AND a higher lift cam to open them up closer still?
You're oversimplifying the entire process. Yes, there still is no replacement for displacement. Bore it too large & you'll potentially have cooling issues, stroke it too much & your piston speed will be too high, limiting high rpm capabilities due to the timing required for the event.
PoorManQ45 wrote:It seems that you guys think that we have 4-bangers in our Q45s. Why is it that when somebody says they want more horsepower, you automatically say forced induction is the only way. That is the thinking of a honda civics owner. We have enough displacement in these engines to make some serious horsepower, Without going with a turbo or supercharger.
No one said it was the only way. IMHO, it's the smart way. Even good standard rebuilt VH45's can't be found in the States, our +/- a hammer handle tolerances are not good enough.
There's many things you can do. It is more expensive & less rewarding to go all motor with a smaller displacement engine. I can install an aftercooled Vortech on a Honda B16 stock long block, at 10 psi, change the intake cam only to a JDM spec Honda cam, header, exhaust, and with no other changes yield 288fwhp/190tq. I can yield 246fwhp/169tq @ 8psi. That's a motor that only produces 160 hp at the crank, stock.
Spend the same amount of money *or more* on an all-motor build, and maybe yield 190 or 200 wheel? I'll take door #1 Monty.
To properly rebuild your VH would run 10k easily, not including all the big baller stuff you mentioned. Does it make sense to spend twice as much money for the same result?
I thought that would contradict your mantra to the core, oh great PVC plenum hose man.
If there was a way to effectively convey tone of voice & inflection here, you wouldn't think I was a d!ck from my post.
