MastaYu's S13 "Ressurection"/rebuild
MastaYu
Car: 92 Nissan 240SX SE HB
Whatsup Everyone! Been thinking about posting up my project for a while now but I wanted to wait until i got some progress going. I bought it pretty busted as you will see in the pics.
Even tho it looked busted up, I thought I would turn it into a drift/street car.
I bought the car in October 07 in NC. It is a 92 with 5speed. I bought it with on 92,000 in it. It didnt have any rust on it other than the hatch. It definatly got owned tho THe brace was busted, the core support obliterated, left side frame rail was blown up, tension rods bent and tie rods bent. The car drived like crap.
Here it is when i first got it.
This is what happened while i was driving back after buying it.
Let the damage begin Yup half a bumper missing and i dont think your suppose to see that brace
Not pretty
Tension rod started to come through the brace.
radiator was also bent real bad
Busted core support Drove the car like this for about 4 months
In Jan. 08 I started to save up money and buy some parts. Here is what I bought.Nismo powerbrace, oem control arms, no name adjustable tension rods.I also purchased a brand new core support and radiator.
At the begining of this summer I handed my car over to Top Quality collision and this is what they did.
New radiator and core support
Power brace in.
Tension rods and c/a in. They also pulled the frame rails and welded them. After this operation my s13 drove alot smoother.
About 3 weeks ago I decided to replace my inner and outer tie rods. I never did it before but i decided to give it a stab.Success! After I got an alignment and the steering felt alot tighter.
The next thing i plan on doing is installing coilovers and work on the rear suspension: subframe spacers, toe rods, etc.
Soravia
Car: 2003 Audi A4 1.8T
I also recommend replacing the Caliper and Rotors with ABS versions. Those are cheaper than non-ABS and also larger. Most old cars don't get replacement pads with shims, which rubs off the fingers on calipers and make pad wear and contact un-even.
Plus I wouldn't trust 16 years old rubber seals on the brake calipers.
Look into replacing your chassis bushings. Those help a lot with ride.
Don't bother much for wheels, spend money on nice set of tires like Yokohama S-Drive, etc. The rubber quality in tires make a great difference.
MastaYu
Awesome thanks alot. Does the abs calipers and rotors conflict with my non abs?
After I blew out my tire, i bought some Falken Ziex512, nothing special but just to move.
Slappy
Car: 1993 240 sx coupe
Nice repairs. You from MD?
MastaYu
Slappy wrote:Nice repairs. You from MD?
Thanks
Yes, I live in moco
Soravia
You can fit in ABS caliper and rotor with no issue. You just need to replace both at the same time. As for pads with shims, get Duralast Gold. They come with perfect fit shims and cheaper than buying generic shims separately.
Before your engine goes bust, remove the upper timing chaing guide, replace the timing chain tensioner and do the valve cover gasket at the same time.
As for oil, I recommend nothing less than Royal Purple and Purelator PureOne oil filter. Go Pennzoil if you can't afford Royal Purple. Pouring SeaFoam into the oil before draining helps.
Slappy
Never even heard of it.
MastaYu
sorry Montgomery county (moco)
MastaYu
Soravia wrote:YOu can fit in ABS caliper and rotor with no issue. Yuo just need to replace both at the same time. As for pads with shims, get Duralast Gold. They come with perfect fit shims and cheaper than buying generic shims separately.
Awesome, Ill add this to my list.
For oil I currently use mobil 1 10w30 high mileage is this a bad idea?
Soravia
Not bad, just so so. But you can get $3.5/qt for 3,000 mile range or you can get $7/qt that can last you 7,000 miles with better lubrication. As for the filter, there is no compromise.
Slappy
MastaYu wrote: sorry Montgomery county (moco)
Ah ok.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
looks good
MastaYu
Soravia wrote:Not bad, just so so. But you can get $3.5/qt for 3,000 mile range or you can get $7/qt that can last you 7,000 miles with better lubrication. As for the filter, there is no compromise.
Royal purple is sounding more tempting.
Slappy wrote:Ah ok.
Are you from MD also?
ca18detgabby wrote:looks good
Thanks, hopefully more progress
Black on Gold
Great fix. Props to those guys at the shop.
MastaYu
Black on Gold wrote:Great fix. Props to those guys at the shop.
Thanks! The shop that fixed is in Anderson, SC
Black on Gold
oh snap. Didnt know that!
MastaYu
Black on Gold wrote:oh snap. Didnt know that!
They definately did a good job, but they are a pretty busy shop at the begining of summer. They couldn't fix my car for a month but its ok, they fixed it up real nice.
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
good project. i gotta get my radiator support fixed too
MastaYu
Flicktitty wrote:good project. i gotta get my radiator support fixed too
Thanks, yeah I hated that stupid rad support. When I found out how much it cost i did this -->
Flicktitty
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
MastaYu wrote:Thanks, yeah I hated that stupid rad support. When I found out how much it cost i did this -->
what did they charge you?
MastaYu
Flicktitty wrote:what did they charge you?
$500 for the rad support than another $500 to put it in.
Flicktitty
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
MastaYu wrote:$500 for the rad support than another $500 to put it in.
holy F'N christ.........
thats a joke right? jebus christ.
Tsukiko
Car: 1990 240sx fastback KA24E
man you got ripped, as far as parts. go to courtesy nissan parts first. even they're a little expensive but you could have bought all of the front end body subframe for about 400.
MastaYu
Nope thats the truth
MastaYu
Tsukiko wrote:man you got ripped, as far as parts. go to courtesy nissan parts first. even they're a little expensive but you could have bought all of the front end body subframe for about 400.
When i checked CourtesyParts at the time the rad support and shipping ended up being over $500 so I decided to just buy it from the shop. Wish i could have bought it for $400 but its all good, its fixed now.
Slappy
MastaYu wrote:Are you from MD also?
21921
MastaYu
Slappy wrote:
21921
Whoa! thats about 2 hours away.
cmoody2006
Car: 1993 Nissan 240sx vert
Wholy crap! That was one busted front end... Glad you got it fixed.... I've still got to order a set of adjustable tension rod's for my car. I was going to offer you my old radiator for dirt but i just read that you got a new one... So n/m It's collecting dust in my storage room. What are your future plans for it so far?
Ps.... I want your fenders............
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
looks good so far, props to bring that thing back from being seriously f*ed up....
idk if i would do the whole ABS swap thing, i think if u just get some hawk pads and slotted rotors u will be fine, if ur gonna swap cailpers u might as well upgrade to q45s, with just simply bending the dust shield, u get get 11 in rotors and still clear stock wheels (teardrops or seven spoke)
MastaYu
cmoody2006 wrote:Wholy crap! That was one busted front end... Glad you got it fixed.... I've still got to order a set of adjustable tension rod's for my car. I was going to offer you my old radiator for dirt but i just read that you got a new one... So n/m It's collecting dust in my storage room. What are your future plans for it so far?
For sure it looksed so much more busted in person but im glad its done now my next plans for the car would be to finish of the suspension by getting some: coilovers (stance or teins), RUCAs, TCAs, traction rods, sway bars, strut bars, subframe spacers/collars. Also work on the breaks. I would like to get the coils first tho.
I dont think you want my fenders they are dinged a bit and paint isnt consistent
hbpignosePA wrote:looks good so far, props to bring that thing back from being seriously f*ed up....
Thanks, yeah i definately was thinking about just getting some hawk pads and some slotted rotors. Im looking for some pads that would be good for just daily driving and maybe on the weekend drifting. Any reccomendations?
