Make Your Own Motor Mounts - Here's How
mrzabala
Car: 93 Nissan 240SX SE Hatch
hey Greg, was wondering if you can give us an update on how this motor mounts holding up and such. If possible can you take pictures to get a better idea? Thanks. JDM and I plan on doing this motor mounts but would like a good idea on what to expect. Thanks.
onosqv
Car: '92 240sx Vert
mrzabala wrote:hey Greg, was wondering if you can give us an update on how this motor mounts holding up and such. If possible can you take pictures to get a better idea? Thanks. JDM and I plan on doing this motor mounts but would like a good idea on what to expect. Thanks.
AZhitman wrote:Latest update:
300 miles since installation, and these are awesome.
I have had to tighten them a couple times, as it seems the little "ridges" on the mounting surface compress a little as it heat cycles.
Notice how the top and bottom of the mount were concave, due to the meniscus of the Flexane when wet (top) and the shape of the cup (bottom).
Nonetheless, I'm super-happy with how they're working out.
mrzabala
Lol THANKS QV. I thought that was a couple weeks ago but it was only 2 days ago.. Sigh. And one thing on frsport. Someone thats avaliable on aim for frsport.com keeps leaving me off when we start a conversation. I made an order but I wanted to add to it before it was shipped. Any suggestions?
onosqv
Car: '92 240sx Vert
mrzabala wrote:Lol THANKS QV. I thought that was a couple weeks ago but it was only 2 days ago.. Sigh. And one thing on frsport. Someone thats avaliable on aim for frsport.com keeps leaving me off when we start a conversation. I made an order but I wanted to add to it before it was shipped. Any suggestions?
NP . I contact you via email to keep this thread on topic .
corey240
Car: 1993 Nissan 240SX Base Drift Machine
so how about subframe bushing replacements? think it would turn out ok for somthing like that?
I think it'd work great for whatever you wanted to make...
I'm going to try it out with a set of tension rods.
greengt2nv
Car: 91 s13 hatch w/super hicas 305 v8 (Under constuction) 99 yzf 600R
F_ING SWEET!!! My motor mounts are ****. and let us know about them tension rod bushings. Oh and just a suggestion. but I think there should have a DIY section on the forum so its not hard to find sweet *** **** like this! just a thought.
Ace 2.0
Car: z32 2+2,1987 CRX si
have you made exaust hangers yet?
maybe next time try sanding the washers with very course sand paper to make it very rough,give the flexane something more to cling to.>>>>A.J.
greengt2nv wrote:Oh and just a suggestion. but I think there should have a DIY section on the forum so its not hard to find sweet *** **** like this! just a thought.
http://www.240sxTech.com
savedz
Car: D21
Tension rods--- yes!!! My Z's tension rods are putting in overtime. Please let us know how that goes as well!
Sky80
Car: '92 240sx Fastback
Hey just a quick thought when i was reading through here.. To avoid a concave shape, you could always use a soup can... just a thought
bone_stock_240
Car: 1995 Infiniti Q45
Sky80 wrote:Hey just a quick thought when i was reading through here.. To avoid a concave shape, you could always use a soup can... just a thought
No, it would still be concave. That is due to the properties of the fluid, and material of the container, not the shape itself, as well as the surface tension of the liquid. If the liquid is attracted to the container, then it will try and stick to it as much as its surface tension would allow. That being said, maybe flexane and aluminum would not have that same attraction, so you may be right.
Touge180
Car: 1990 Nissan 240 se
i found a great place to get mounts from jgstools.com come i got my semi solid mounts from them for about 150-180 i cant remeber which but their just fine if you can deal with vibrations
Yeah, the meniscus of the fluid creates a slight concave shape. Realistically, once they're bolted in, it's pretty irrelevant, but I trimmed and smoothed the edges of mine anyway.
rear_wheel_559
im tryin out this idea of urs..were did u order the flexane 94...and how much?...dont no were to find them..
It was like $50, not sure where I got it from. Google it?
eazye2000
Car: S13 KA-DET
AZhitman wrote:It was like $50, not sure where I got it from. Google it?
This is what I found... http://www.markingpendepot.com...D=193
I've already urethaned my stock motor mounts, so I'll try that first. This is next on the list if I don't like it.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
These would not be a good idea for tension rods, for the same reason that stiffer busings (whiteline, energy suspension) are not a good idea for the tension rods.
Your best bet for awesome, reliable tension rods are high misalignment spherical bearings or heim joints/rod ends.
mrzabala
eazye2000 wrote:This is what I found... http://www.markingpendepot.com...D=193
I already ordered 2lbs for 2 sets of motor mounts. Hopefully it will work so I work on my wiring. Question for you Greg is can you inform us on how the motor mounts are right now or sometime soon? And happen to have any ideas for improvement (before I start making mine)? Thanks
I wouldn't change a thing. I snugged mine up after 24 hours and they've been perfect since.
I'm convinced this is the BEST way to go for motor mounts.
mrzabala
Thanks for the input. Ill be getting mine on monday so Hopefully I can have it in 2 cars soon and have a test drive.
BlueTyGator
Car: 1992 240SX SE
Anyone given any thought to using this stuff on the transmission mount?
I need to replace all three mounts and was thinking about how I could fab up one for underneath.
Advice/suggestions?
Should be simple. Look at the factory mount and decide what needs to be done.
White Comet
Car: fc, s13 and mazda6, Sierra
back from the grave...hmmmm someone is taking after me
ZiG
Car: 1993 240sx coupe
So, uh, any word on tension rods? I'm curious how they could be done so that they would stay in place.. Or would you just 'cast' them right in place?
98s14inaz
Car: 2010 Nissan Titan Quad Cab
AZhitman wrote:Ah, sorry. Yes, an update would be good!
OK, at idle, it's a little rougher than the Nismo mounts were. Good thing we went overboard having this rotating assembly balanced.
Once I accelerate, it smooths right out, and feels smooth as ever. Believe it or not, the car actually feels more "solid" or "well-planted".
I'll be inspecting them after every drive for a while to ensure they're holding up well, but I did several full-throttle runs and it felt great.
I just stumbled on this thread. Simply amazing. I will offer a suggestion though. You mentioned that you had to tighten a few times because the urethane compressed in places. Why not put a large washer on the top and bottom when you are forming these. Basically Put a washer in the bottom of the cup, put the bolt through it, pour in goo, put a washer on top of goo. This should also keep the bolt centered in the cup.
nissan4ever66
Car: Nissan Altima Coupe, 300zx Twin
U my friend are one Smrt I mean SMART person Amazing
ZiG
lol, yeah, put a washer top and bottom, wtf would you even need the flexane for!
qat727
AZhitman wrote:OK, at idle, it's a little rougher than the Nismo mounts were.
I saw this when you first posted it up and I still think it's a great idea. I do have a question, though. Do you think it might be a little more civilized if you used Flexane 80 instead?
mrzabala
Made this motor mounts awhile back, pretty much the same way Greg made it. Ran for about 500-600 miles. Its rough at idle. I had to raise idle to 1500 to keep it somewhat smooth. Literally feels like your in the vibrator bed in a chiropractors office. Everything blurs out on the rear view mirrors and side mirrors, if your transmission mount rubber spacer is cut off, it makes even more noise. On the positive, the turns are awesome. Grips so much better. Recommend this for the drifters, but not for commutes.
