Make Your Own Motor Mounts - Here's How
ZiG
Car: 1993 240sx coupe
Well, it beats the hockey puck motor mounts, that's for sure.
98s14inaz
Car: 2010 Nissan Titan Quad Cab
ZiG wrote:lol, yeah, put a washer top and bottom, wtf would you even need the flexane for!
You're kidding right? The flexane gets sandwiched in between the washers. Just use a little less to compensate for the 1/4" the washers add. Doing it this way spreads out the contact surface area and prevents the uneven compression in the places that Greg mentioned. Do it any way you want, I'm offering up a suggestion to improve an already great idea. Greg knows I don't ghetto rig anything.
Modified by 98s14inaz at 1:09 PM 10/1/2007
qat727 wrote:
I saw this when you first posted it up and I still think it's a great idea. I do have a question, though. Do you think it might be a little more civilized if you used Flexane 80 instead?
Not sure - You'd want to look at compressibility and tensile strength.
There's nothing "civilized" about a 400-hp convertible with 400 lbs of weight removed.
ZiG
98s14inaz wrote:
You're kidding right? The flexane gets sandwiched in between the washers. Just use a little less to compensate for the 1/4" the washers add. Doing it this way spreads out the contact surface area and prevents the uneven compression in the places that Greg mentioned. Do it any way you want, I'm offering up a suggestion to improve an already great idea. Greg knows I don't ghetto rig anything. Modified by 98s14inaz at 1:09 PM 10/1/2007
Oh, i thought you meant fix the washers with nuts just as it is in the middle, which, of course, would put the load pretty much entirely on the threaded bolt.
98s14inaz
Greg, one question before I try this on my new ride...
AZhitman wrote:(2) 4" 12x1.25 allthread rods (Ace Hardware has them)
Are these threaded rods graded?
Yep - Grade 8.
nismo8117
Car: 93 SilLine
awesome write up! you da man!
