94Q45Beast »
https://forums.nicoclub.com/94q45beast-u244772.html
Thu Oct 01, 2015 8:40 pm
I replaced my duralast fuel filter with a fram, no change......I decided to reset the IAC valve and I had to turn the screw 4 full turns to get it to idle at 850-900rpm and then slowly the idle came down to 650 rpm on its own and it's just staying there smoothly...but in gear other than "P" and "N", it drops down to 500-575 rpm statically (not smooth).......No cel light meaning it can't be the maf or IAC or any electrical...the connector is really snug now on the maf.....it can't be my fuel system...no noise from the fuel pump or fuel smell in the trunk...fuel pump is exactly 27,453 miles old bought directly from the dealership, and recently inspected all injectors and changed out the bad ones with new fuel hoses that keep coming loose every couple thousand miles. and I run 104+ octane booster with total fuel system cleaner every month (surprisingly I still get only 12 mpg combined city and highway driving), seafoam every 10K miles (did that today), I even did a fresh oil change + filter with my "go to" setup to see if that helps my idle problem (penzoil ultra platinum with pure plus tech, 5w-30 with Mobil 1 Extended Performance filter), secondary TPS was changed, spark plugs are roughly 10K miles old...TB is completely clean and so is the Plenum and lower runners ( scrubbed clean every 30K by hand, all 10 pieces, I don't mind paying extra bucks for hoses from the dealership, and i haven't needed to change any besides the pcv valve hose).....I did a transmission fluid dran+refill 11K miles ago and did it again 7K miles ago and dip cleaned the Transmission filter in fuel .I'm clueless on where to look...my coil packs are also in good condition and were checked when changing the plugs.....I consulted the FSM and i looked through it and last option was a bad ECM...'...I really hope not....I'm stuck on this riddle.
