What do you mean the mount points are gone? Wondering if I'm wasting my time getting the shield at all. I search and find posts where it was discussed to remove it completely. The consensus was that is served a purpose and should be install.
Makes sense. Thanks for your input. Can you shed some light on the other piece that I'm missing? #7 in that diagram? Again, every one I find says it's only for the base RWD M56 and not the AWD M56x. I have to believe they're the same, but want to have someone confirm before I order it.Ilya wrote: ↑Wed Jul 31, 2019 12:18 pmThe bottom of your bumper has mounting points for the OEM shield. After years of upstate NY winters, salt, etc...those u nuts tend to deteriorate due to aforementioned salt, vibration, wind, etc. Whether you use the aluminum shield (which is way more convenient for oil changes) or the OEM plastic garbage, you'll eventually, years down the road, run into the same issue.
I don't see shield #7 in your pics. I see the main shield #1 which I just ordered per your recommendation, and #9 rear shield. I don't even see where #7 would go?Ilya wrote: ↑Wed Jul 31, 2019 1:48 pmEDIT: Sorry, misread, you mean a shield from the very back of the car.
If you look close on this pic, I think I have that shield:
I have that #7 shield on my car. Pictured here (bottom of pic):
From this thread: howto-change-the-oil-m56-vk56vd-t594953.html
Obviously it's off the picture, but I labeled it #9 because it looks more like that than #7. I would like to see a picture of what all of them look like mounted to the bottom of the car. The front one is easy, but I don't see where #9 and #7 even go. I've searched and searched and could not find such a diagram.
Now it's making more sense. Thanks a ton for your guys help.Ilya wrote: ↑Wed Jul 31, 2019 7:39 pm#9 is this, from my air filter thread:
howto-replace-air-filters-m56-vk56vd-t594952.html
Thank you so much, I really appreciate it!
