Somehow missed this....Thanks!iwk2much wrote:Your car sounds great and an attention grabber when rolling! Nice job.
Those are cool. I admire the level of customization you've gone to. Pretty sweet without going too far and destroying the beauty of these cars and how they've been designed.Debonair wrote: ↑Thu Aug 17, 2017 12:33 pmOrdered a set of these 6K/3K switchable LED bulbs for my fog lights. Turning them on/off/on changes them from 6k white to 3k yellow which is pretty cool.
They default to white which I don't like so I might de-solder and swap the wiring so they default to yellow instead. Also ordered new bulbs for my DRL's. Pics and/or video of both to come.
-knelson wrote: ↑Thu Aug 17, 2017 12:55 pmThose are cool. I admire the level of customization you've gone to. Pretty sweet without going too far and destroying the beauty of these cars and how they've been designed.Debonair wrote: ↑Thu Aug 17, 2017 12:33 pmOrdered a set of these 6K/3K switchable LED bulbs for my fog lights. Turning them on/off/on changes them from 6k white to 3k yellow which is pretty cool.
-DoN_BLaZe34 wrote: ↑Fri Aug 18, 2017 7:11 amSo do they operate as another set of DRL's? I'm a bit confused as to how these will work as fogs..
just installed these as well - driver side pretty easy to get to, didn't have to pull everything apart....passenger side is another story, darn windshield washer reservoir tank in the way, so had to remove the wheel liner so I had enough room to work in. I didn't swap the innards because I want the white to be the default. I was using 3000K LEDs from IJDMtoy before this (got lucky, cuz' I know Ilya had a lot of probs with them - their quality control is for sh*t, I had to glue/crimp one of the bulbs because it was freely spinning around in the socket base) hopefully these last a while
pedsemdoc wrote: ↑Tue Oct 03, 2017 10:22 pmjust installed these as well - driver side pretty easy to get to, didn't have to pull everything apart....passenger side is another story, darn windshield washer reservoir tank in the way, so had to remove the wheel liner so I had enough room to work in. I didn't swap the innards because I want the white to be the default. I was using 3000K LEDs from IJDMtoy before this (got lucky, cuz' I know Ilya had a lot of probs with them - their quality control is for sh*t, I had to glue/crimp one of the bulbs because it was freely spinning around in the socket base) hopefully these last a while
Thanks Debonair for the nice find!!! I really like these.Debonair wrote: ↑Thu Aug 17, 2017 12:33 pmOrdered a set of these 6K/3K switchable LED bulbs for my fog lights. Turning them on/off/on changes them from 6k white to 3k yellow which is pretty cool.
-pedsemdoc wrote: ↑Thu Oct 05, 2017 1:33 pmThanks Debonair for the nice find!!! I really like these.
So FYI, not sure if others' sets might do this, but if you rapidly flick your high beams (like trying to get an older tech stale red light to change - not sure if this is urban legend or not) you might get one fog light to be 6000k and the other 3000k, noticed that a few nights ago. I was a little worried that I would never get them to be in sync again, BUT a rapid high beam flick a couple times sorted it out, thankfully - I only wish I could easily tell which color was shining without having to see them bounce off a window or a dark colored car in front of me, but that is a nitpick.
