m35 / g35 / 350z part interchange
thm8d
Car: 07 Infiniti M35 Sport w/ Tech pkg
It'll straight bolt on and wont ride like s***. I'm sure it wouldn't matter to the dealers. Coupe and sedan have the same struts. Just valved differently for different springs
tbright
Car: 2007 m35
Re: Z-Tube
I just tried a Z-Tube from a 03-04 G35 on my 07 M35. The vacuum line is way off. [Yellow Highlight] M35 line comes joins at the top, about 4" from the end. G35 is about 8' from the end and on the bottom. You could possibly force the existing one into place or add an extension an reroute it. Mounting bracket [Red Highlight] also doesn't line up.
Anyone else have any luck with this? Did I give up too soon?
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
When I had my ztube, it lined up properly...no issues, if I remember, I just ran the hose to the bottom without any extensions. I had an OEM Ztube....
the side by side picture of the stock vs Ztube inside of this thread is from my set up when I swapped out the stock M35 intake tube for the OEM Ztube...you can see where the hose is connected to the Ztube (at the bottom).... no issues.
stillen-z-tube-or-injen-intake-t591118.html
Freshjive80
Car: 2007 M35
Will aftermarket High Flow Cats (HFC) meant for the 03-06 G35 coupe fit directly with my 2007 M35 with VQ35DE motor?
I'm looking at Fast Intentions resonated HFC because of their reduced sound and smell.
http://www.fastintentions.com/product_i ... cts_id/111
cruzad3r
Car: 2006 Infiniti M35x fully loaded
didn't you just buy the Berk HFC from someone in the other forums?
Freshjive80
Car: 2007 M35
cruzad3r wrote:didn't you just buy the Berk HFC from someone in the other forums?
Nope didn't buy any HFC, just inquired about pricing. I was about to purchase the FI HFC but they won't sell to CA residents because of CARB regulations. :mad:
cruzad3r
so my understanding is that any HFC or test pipe for the VQDE35 engine will bolt right up. I know people here have used Berk and Kenetic. If you look online, you can see there are tons of options. I'm considering a new pair from Megan because they're like 150 brand new. However if i can find a good used BERK, i will most likely buy that as they have the original holes for the bracket.
the bracket in question is the U-Shape underneath the car where it bolted on to the side of the HFC. the cat itself has three bolts on either end to attach itself to the Y-pipe and the Exhaust Manifold.
Freshjive80
Car: 2007 M35
I'm debating on Berk but the price is a little high. So my main concern would be how the bracket and holes line up?
YoungGuccii
Car: 06 Infiniti M35 base
Hey everyone can I get some help I got a 2006 Infiniti M35 base and I’m wondering if the headers / y pipe / cats from a 350z or g35 would fit on my car or not?
YoungGuccii
I just really want my car to sound nice, everything is stock other then my rims and windows tinted and tail lights tinted
1MeanM
Car: 2003 Nissan 350z
Does a M35x rear diff fit a 03 350z? Has the same part number on the housing just curious.
Also, does the M35x have a VLSD in the rear? Thank you guys.
Shecanic92
Car: Infiniti m35x
Hey guys, I know this is a super old thread but I have an 06 M35x in need of new front cv axles for both sides. Went to replace wheel hub and had a grease mess. Sure enough, both inner boots are cracked. I'm thinking just replace the whole axle(s) for fear of debris in the joints. I'm finding a better deal on G model axles.. can anyone confirm if any are interchangeable??
-liz the shecanic
AWD btw
For now I degreased the outside of the old boots, sealed cracks with red rtv, & filled with valvoline synthetic high temp.. crossing my fingers this will get me by till I get new axles. No clicking so hopefully the cvs didnt get too much damage. No idea how long they've been cracked.
Tmason87
Car: 2007 Infiniti M35
2004 Infiniti G35 coupe
Hey, I have a 07 m35, I put g35 coulover on it, only problem I had was on the rear the shock part was too short so I had to put the stock shock with the new spring and adjusters, with the coulover shock the car set way to low . But other than that it rides decent and looks awesome,. :bowrofl: :poke: :slap: :mike :wavey:
