m35 / g35 / 350z part interchange
anotheraznguy
Car: 2005 Nissan 350z
1989 Nissan 240sx
2006 Infiniti M35
Wanted to revise this thread..
This is going to be an interchange thread of those that are confirmed / denied / speculation
with the 350z/g35
Confirmed
Cats
Y-Pipe
Z-Tube
Upper / Lower Plenum
Underdrive Pulleys
Anything that bolts onto the VQ35DE internall or externally (Dependent on chassis clearance)
Speculation (Try at own risk)
Brake swap
Rear Camber Arm
Rear Toe Bolt
Rear Traction Arm
z/g Differential
Coilovers / Spring Shocks
M35-M45 Exhaust Compatibility
Radiator
Does Not Fit
Air Filter
Cabin Air Filter
Front Upper A-Arm
Front Lower Arm
Front Knuckles
Sway Bar
M35-M45 Differential Swap
Last edited by anotheraznguy on Tue Aug 14, 2012 9:00 am, edited 2 times in total.
Freshjive80
Car: 2007 M35
BUMP! I would also like to know a list of parts that are interchangeable. How bout coilovers that were meant for the G35 coupe?
anotheraznguy
1989 Nissan 240sx
2006 Infiniti M35
so...
y-pipe confirmed
High flow cats confirmed
z Tube - confirmed
I haven't messed with suspension yet mainly cause my wife doesnt want me to put my z coils on the M
Marcus123
Car: 2003 350z - Totaled
2006 M35 - Current
Gonna do a test of 350z stock suspension on an M. From the looks everything matches up. We'll see how it goes and what kind of drop it will be if any. Pictures should be up this weekend!
anotheraznguy
1989 Nissan 240sx
2006 Infiniti M35
i looked it over when i was installing y-pipes this past weekend.. it looks very similar. however one thing i noticed is even on the rwd M35 the front lower control arm and knuckle is different from z/g.. instead of a seperate control arm and compression arm it is a triangle arm on the m. the other thing i noticed was the upper control arm and wishbone is different as well on the M...
marcus.. can't wait to see before and after pics of the M w/ the Z suspension.
what yr is the suspension from cause in mid 04 they revised spring rates and such..
Also.. are you swapping dampers as well or just springs? Let us know how it rides.. Thanks
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
what up guys...here are a few items (stock and aftermarket) -- Keep in mind that I have the M35 sport, so unsure of some suspension fittings for M35x
upper and lower plenum
plenum spacer
wheel spacers
-- unconfirmed:
radiator (would like to run Mishimoto on mine)
shocks (front/rear)
engine mounts
EniGmA1987
Car: '06 Infiniti M35 Sport
anotheraznguy wrote:anyone know if the rear differential is swappable or if m35 and m45 are interchangeable?
100% no. I have been under there and seen them and The M45 is completely different in its rear end drive area. To start, the input shaft to the read diff is larger. Then the rear differential itself is much larger and has a different bolt pattern, the spline count is also different. The output shafts going to the wheels are also much larger, different bolt pattern and spline count and length.
Now thats not to say you cant get it done, you just need to modify the mount a little bit and also buy the rear axles and replace those at the same time if you swap the differential in an M45.
As for the M35, it should be 100% bolt on compatible with the G35's and specific year G37. I say should, because I havent seen for myself all the years of those cars and dont know for certain that everything on all years is the same. My G37 rear differential came from the single year you could get a G37 with a 5 speed transmission, the same 5 speed that our car uses. I have no idea and doubt that the models from the 7 speed transmissions will be a direct bolt on.
Freshjive80
Car: 2007 M35
I was hoping my 05 g35 diff with VLSD fits my 07 M35 :(
I will soon test fit on my M35 the following g35 parts:
Stance coilovers, Megan rear toe arms, and SPL camber arms, Megan UCA
anotheraznguy
1989 Nissan 240sx
2006 Infiniti M35
sweet.. so i updated the list..
lets see what happens with the suspension compatibility
Marcus123
2006 M35 - Current
It's coming off an 03 so it's not the revised suspension. I'm not doing the struts as of right now but I will be taking some measurements so I could go with them if need be in the future. Should be happening Friday and Saturday.
Se@ttleM35S
Car: 2006 Infiniti M35 Sport
So with the limited supply of reasonably price body kits for the M's, I have been wondering if any of the lip kits are interchangeable... Has anyone attempted to test fit a lip kit from a G35/7 sedan on a M? I just wondering...
Marcus123
2006 M35 - Current
Se@ttleM35S wrote:So with the limited supply of reasonably price body kits for the M's, I have been wondering if any of the lip kits are interchangeable... Has anyone attempted to test fit a lip kit from a G35/7 sedan on a M? I just wondering...
This is also something I'd be interested in. I had an old 350z lip I had laying around that wouldn't have fit at all but a G35 or G37 might be closer.
EniGmA1987
The width on the G's is actually pretty close to the M. It might actually work with just a slight bit of modifying.
Marcus123
2006 M35 - Current
From Wikipedia:
M 06-10
1,798 mm (70.8 in)
M 11-
1,845 mm (72.6 in)
G 03-07
1,815 mm (71.5 in) (coupe)
1,750 mm (69 in) (sedan)
G 07-
72.9 in (1,852 mm) (convertible)
71.8 in (1,824 mm) (coupe)
69.8 in (1,773 mm) (sedan)
I don't actually know where this is measured from I assume whatever the widest point is.
Freshjive80
Car: 2007 M35
I was able to fit my stance coilovers that were on my '05 G35 coupe on my 2007 M35! Direct bolt on with no issues.
CPJ LB
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
Freshjive80 wrote:I was able to fit my stance coilovers that were on my '05 G35 coupe on my 2007 M35! Direct bolt on with no issues.
NICE!!! Knowing that the G35's have sooo many suspension choices...this is good news. My buddy says he has the Tokico HP (blues) shocks/struts and his ride is excellent (06 G35 coupe) -- also lowered on springs..... I may have to give these a try....hmmmmmm
Marcus123
2006 M35 - Current
Did it drop you too low? I thought I read somewhere that Z/G coils at the highest height are lower than M coils at the lowest. Do you have pics of it afterwards? If this works it could open a lot of different options for coilovers besides the usual D2/Megan.
anotheraznguy
1989 Nissan 240sx
2006 Infiniti M35
one of the concerns is the weight. especially w/ the z/g shocks compared to the M it has an extra 500-1000 lbs over the g. This could cause a crappier ride quality.
Coilovers i wouldnt be too concerned but when going w/ oe style shocks that are not damper adjustable could be an issue.
Def wanna see what stock z springs do on the m
cruzad3r
Car: 2006 Infiniti M35x fully loaded
frikin X version - what a pain in the @$$ - i need to replace my suspensions and the front sets are about 400 shipped. it seems there aren't any interchangable parts from the older Z or G coupe/sedan.
what the hell!!!
anotheraznguy
1989 Nissan 240sx
2006 Infiniti M35
have you looked at the g35X shocks? they might be similar knowing nissan/infiniti
cruzad3r
I have but no way to know for sure since i have nothing to compare to and i don't want to buy the parts that end up don't work
mexillis
Car: M45s
Marcus123 wrote: If this works it could open a lot of different options for coilovers besides the usual D2/Megan.
there are a lot more than those two for coilovers, Jic magic, Tanabe's new 40 way adjustable, Tein has a couple different one's, K sport, BC racing and then there's some in Japan that no one really gets like Rs R and Impul just to name a couple.
anotheraznguy
1989 Nissan 240sx
2006 Infiniti M35
So after a car show this weekend where i was takling w/ a fellow M owner.. It appears that.
350z / G35 front brakes do not work without an adapter
370z / G37 Front brakes bolt on
350z/g35/370z/g37 rear brakes all work..
Anyone want to double confirm my findings?
rxmclaren7
does that include the brembo brakes?
mexillis
Car: M45s
yep g35 brembos dont bolt on and g37s akebono's do, personally Id get the bigger of the two if I was debating. Also Evo brembos bolt on with a custom adapter along with mercedes amg 8 pot. Ohh and there's some brakes fs here http://york.craigslist.org/pts/3206242131.html great deal too!
cji4130
Car: 2006 M35x
CONFIRMED. none of the Megan racing Y-Pipes will fit in an M35x. straight from the source.
"Greetings CJ,
We do not have a Y-pipe that is fits your AWD application. Please check your local laws and regulations regarding emissions legalities. It is definitely illegal in the state of California to remove a functioning catalytic converter.
Thank You,
Arjay
TECH/R&D
MEGAN RACING INC.
788 PHILIPS DR.
CITY OF INDUSTRY, CA 91748"
This being confirmed, can anyone help me out with my options. I'm in desperate need of a new y pipe for my m35x and im not really looking to buy a new or used OEM, but if those are my only options...i have heard that the FX35 y pipe fits the m35 (non-awd), possibly would the FX AWD fit?..looking forward to hearing from you guys.
thanks,
cj
CPJ LB
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
cji4130 wrote:CONFIRMED. none of the Megan racing Y-Pipes will fit in an M35x. straight from the source.
"Greetings CJ,
Thank You,
Arjay
TECH/R&D
MEGAN RACING INC.
788 PHILIPS DR.
thanks,
cj
I believe you will need the ypipe from the G35 VQ HR style. The HR style has a wider look than the "DE" style.
Take a look at this thread and you'll see the HR style ypipe. also Megan makes the HR style ypipe
http://www.niclub.ca/forums/showthread. ... -HR-y-pipe
http://www.meganracing.com/product_deta ... 1&catid=10
cruzad3r
I looked at the parts on ebay; specifically megan parts number for m35x and g35 hr motors and y-pipe as well as hfc are the same. Of course i haven't buy the part to test them out yet. They're cheaper compare to the rest after market manufacture so it might be a ''cheap'' investment to test :-)
CPJ LB
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
cruzad3r wrote:I looked at the parts on ebay; specifically megan parts number for m35x and g35 hr motors and y-pipe as well as hfc are the same. Of course i haven't buy the part to test them out yet. They're cheaper compare to the rest after market manufacture so it might be a ''cheap'' investment to test :-)
true...also try and get an HR ypipe from the G Forum classifieds...really good prices....
cji4130
Car: 2006 M35x
"Greetings CJ,
Thank You,
Arjay
TECH/R&D
MEGAN RACING INC.
788 PHILIPS DR.
thanks,
cj
I agree that the HR style y-pipe from megan looks a lot like the current y on my M. but i emailed Megan racing and they specifically told me it will not fit. i mean, should i just buy it anyway to see if it fits, even though they told me it would not?
