Nah. Got my gat and IB ready to go...Nismonkey wrote:You can drive by... Stay for a while too
I also have a 2000 maxima.that intake is tuned for low and mid range torque.When I replaced it with my Berk intake (which I highly recommend) I immediately noticed a loss of low end grunt, but it now pulls like a freight train in the upper RPMs (and gets better MPG). After driving it a week I forgot what it used to feel like down low.BOBCAT wrote:I cant believe the intake on my car is only like an inch in diameter. Im cuttinga ginormouse hole in front of my air filter!
Does anyone here know where I can get a climate control for a 00-01 not a 02-03?? half of my lights dont work on it no more so I am just going to get a new one.
You can have my '02 digi that I have sitting around to see if it will workBOBCAT wrote:I cant believe the intake on my car is only like an inch in diameter. Im cuttinga ginormouse hole in front of my air filter!
that might sound like a plan. The only diff on it is the readout of the outside temp button. You have yours on your gauges and mine is on the climate control. I will try that out. Let me know when a good time is.Did you come to the meet??audtatious wrote:
Since the '00-01 and '02-03 are slightly different externally, the actual digital readout may be the same. If that is the case, you can hack into yours, remove your screen, then replace the bad with the panel from the '02 I have....
