lolwut... autocross in a truck
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
flohtingPoint
Car: 2004 Z16 Corvette Z06
PEZi720 wrote:well i can tell ya... that run has about as much apex as a banana
it was seriously a terrible run.... and TERRIBLE understeer
+2?
I love the large slalom setups with the numerous cones.
PEZi
flohtingPoint wrote:
+2?
are you talking +2 cones? if so it was only +1 on that run
i would have liked the multi-cone slalom had it not been that location... there's a lot of surface issue there and some of it is not noticeable in the video
a few guys blew shocks that day (video 2) and i personally destroyed the dust boot on my front passenger shock
Modified by PEZi720 at 11:08 AM 9/7/2009
flohtingPoint
Yea, cones. My bad, I thought I heard 2, possibly three. At times they can sound like suspension rumble, so I must have just been hearing that, or I was hearing my head pounding as I had a bit too much to drink last night (celebrating a decent test and tune session, for others, not for me =P).
I can see the course issue quite well, it looks like you were VC'ed (victim of the course, something we say here in DC) when you locked up. Fed Ex Field, where SCCA holds the solo's out here, has two different surfaces and elevation changes. The tarmac is all too unpredictable at times for folks w/out current vehicles or folks not running top tier rubber (v710's or A6's).
PEZi
yeah... our surface is relatively uniform... but it is full of cracks and 'jumps'... the jumps are the suspension killers
flohtingPoint
PEZi720 wrote:yeah... our surface is relatively uniform... but it is full of cracks and 'jumps'... the jumps are the suspension killers
Truck specs for curiosities sake?
PEZi
as in basic specs?
power: roughly 100whp at sea level (not as much here in CO) though it hasn't been dyno'dsuspension: KYB struts with lowered stance (3ish inches in the front and 2 inches in the rear)... heavy duty endlinks in the front... and for the video from outside of the truck (and to this day) there is between -3.5 and -4 degrees of camber weight: around 2,200 but will be less once build is done... interior looks like this
more info can be found in my build thread... though after reading the rules closely i have rethought a few of the things already zerothread/438016
PEZi
almost forgot to mention... i'm on street tires... BFGoodrich G-Force Sports
ashley_marie
Car: 2004 Xterra and B13 Sentra Se-r
Killing it man. Nicely done in the 720!
flohtingPoint
Any more events this season? I think I have at least 5-6 scheduled and two track days left before the winter shutdown.
Project Trucker
Car: Datsun 720 pickup
hey for your door you should go and craft side piece out of diamond plate or our of fiber board
PEZi
flohtingPoint wrote:Any more events this season? I think I have at least 5-6 scheduled and two track days left before the winter shutdown.
we have the last one this sunday...winter comes too fast i suppose
but... some interesting news... by truck is now an EP build so I need to be able to beat you lol
Project Trucker wrote:hey for your door you should go and craft side piece out of diamond plate or our of fiber board
eventually there won't be anything there... just the side guides for the windows which will be lexan and a little peg if they need to be held up
flohtingPoint
PEZi720 wrote:we have the last one this sunday...winter comes too fast i suppose
No EP for me next year =( Spoke to several of the folks that impound the cars for the nationals and they said that even though my motor is a 4ag, it's still considered a motorswap, so the car would be SM or DQ'ed if I tried to run EP.
The Corolla's plans have changed, it'll be my HPDE car next year as I plan on doing NASA. My MR2 will be built for STS for SCCA next year. I have a build thread in the "others" section going on right now, but nothing significant as I'm still awaiting parts/financing the project.
PEZi
how is it a swap? the guy i know has more work than yours on his 4ag... and he took 2nd at nationals btw
flohtingPoint
PEZi720 wrote:how is it a swap? the guy i know has more work than yours on his 4ag... and he took 2nd at nationals btw
Yea, I saw the nationals sheet. Someone I know up here took ESP for the ladies, Kraus.
There are several types of 4ag's. Just a quick rundown:-Bluetop: Called that because of the blue lettering on the valve cover (this is the motor that was originally in my car)
-Redtop: Again, because of the lettering. Higher compresssion in this one. Came in AE92's and a couple other cars. The guy you know either has one of these or a Bluetop, as both, on the outside, look the same to an uninformed invididual. You can, however, tell the differences, as 7 rib block is a giveaway.
-Silvertop: Never released in the states. Came in Trueno's and Levins. High compression once more. 20 valves instead of 16, also VVT.
-Blacktop: What I have in my car. Came from a AE111, never released in the states. 20 valves, VVT, higher compression than the Silvertops. Basically the cream of the crop as far as 4AG's go.
Because I do not have a bluetop, it's considered a motorswap. =(
I've wanted to get into NASA since I got back from Germany anyway, and having a dedicated car for such sounds good to me, so my MR2 will be my cone-car. =)
PEZi
the guy i know runs 12:1 compression... dunno exactly what that means
but this sunday i'll running against 2 guys in an '83 celica and an '85 AE86 in EP!
flohtingPoint
PEZi720 wrote:the guy i know runs 12:1 compression... dunno exactly what that means
Weisco sells several different piston configurations for the 4ag. I happen to have 11:1 pistons laying around my house waiting on a reason to use them.
Sweet. Pics please!
PEZi
will do... i'll get some interesting grid shots of some actual prepared cars next to a truck... if i win i will lol uncontrollably
flohtingPoint
PEZi720 wrote:will do... i'll get some interesting grid shots of some actual prepared cars next to a truck... if i win i will lol uncontrollably
How did you get bumped up to EP btw?
Edit: Any chance you'll make it to any national events next year? Depending on how my STS build goes and how the car treats me, I plan on doing my mandatory 2 events so that I can possibly go to the nationals next year.
PEZi
i'll be going if i get enough money to build my suspension up well enough for EP and get consistent fuel delivery and some r-comps...
but i'm in EP because i technically don't have a class... and they will be putting me with cars that share engines closer to mine... almost all the datsun cars (510 etc) run EP... i had to write a letter to scca just to be classed lol... if i didn't write them a letter asking for classing i would have been DQ'd trying to enter a national event
flohtingPoint
PEZi720 wrote:i'll be going if i get enough money to build my suspension up well enough for EP and get consistent fuel delivery and some r-comps...
Nice... Leave it to the SCCA to ignore a vehicle's classification. My MR2 is already outclassed in STS, but I think with a proper build I can make it competitive... Hopefully. I plan on investing 7-10k on the car (including body work and paint due to major rust), so hopefully it wont be for nothing.
As far as tire size goes, what are you looking for. I can keep an eye out if I see any used deals in the DC metro area.
PEZi
well... lol
i need to save up the money to at least start the suspension before i get tires... and at the very least get a new carb too... then i can move to the tires for which i will also need wheels for...
but i'll be looking into 13x10 wheels with 275 hoosiers
flohtingPoint
PEZi720 wrote:well... lol
Just A6's you're looking for, or would V710's do? Like I said, I'll keep an eye out in my area. The DC area is massive for autox, as we hold one of the national events and our level of competition is massive, so plenty of used tires go around.
PEZi
we got tons of used tires too... its just every time they come up i have no money... but yeah v710's are fine... but if i can afford the a6's when it comes time i'll take those
initial_jc
Car: KOUKI
that looks like so much fun in the second video
daxon22
Car: 1986 nissan 720
Dude Pezi WTF is up with the youtube vids in your sig man ?!?! Your almost able to hit the bar and club scene and this girl is 15 !!! Not cool man !
seang
Car: Ford Fiesta ST
Her channel says she's 22, and I would do things to her with my everything.
daxon22
Thats not her channel read the comments . Click on the first one pezi has listed and read up on the letter her parents posted, says shes 15 . She is a pretty girl but shes 15.
daxon22
I take that back on that not being her channel. But the letter her parents posted says shes 15. Not a big deal but if she is 15( and she looks like it ) thats effed up.
PEZi
those videos were awesome!
i had to remove them tho cause they auto embedded for those using fireNICO making my sig too big
Nissan_Boy85
Car: 85 Nissan 720
i got some vids of mah 85 running some cones...but where are they...
http://www.youtube.com/watch?v=Qxdo58UN ... ?v...lated
Man pezi, either I gotta go out there or you gotta come out here. I would love to run with another 720, or even another pickup in general.
Return to “Datsun 720”
