lil89ram50 »
https://forums.nicoclub.com/lil89ram50-u138282.html
Tue Aug 11, 2009 9:02 pm
i put my truck on ramps and then drain it into a 5 gal bucket.... might wanna get some engine degreaser, and fill the rad with the engine degreaser and water mix and flush the motor....... jus put the gal of degreeaser in, then fill with water, start the motor, then let warm up, then jus keep filling with water...... it will start to over flow, then put the cap on, let it run for 5-10 mins, then drain, fill with your antifreez/water mix and your good to go! you wouldnt imagine the s*** that will come out! im going to be doing this to mine when i switch my fluids in a couple weeks..... might be a good idea to change out your thermostat, there cheap, and since your already workin on it.....
