HeavyDuty,
Sam specked the stall speed at 2,600 to 2,800. He advise that the car must be making a lot more torque than we all expected and it is not locking until 3,200. The only way I can drive it at the moment is flat out or nothing. I will be specing it as low a possible. Apparently the lowest you can go on a billet converter is 2,400. I would still like to go a touch lower.
rsiwicki,
Glad my info on how to identify the different years was helpful.
dkill,
I am running genuine NASCAR 4:11:1 Ford 9" gears (31 spline) with a trutrac helical gear LSD all wrapped in a harrop billet low profile 9" housing, the same as the one in the VT commodore on the following link.
The trutrac locks up both wheels almost instantly and puts the power to the ground evenly.
The only thing that I am not sure about now is wether or not I need to customise/fit heavier duty axles. I think this is the weakest part of my whole drivetrain.
http://www.harrop.com.au/produ....html
I am also running a genuine Nissan Motorsports diff cooler.
Regards
AGM
