Just did mine up myself. Bought the Clutches, gasket kit & Band from Level 10 & all fitted great.
I put in Castrol Synthetic oil & it's green! Thought I was using Brake fluid to start with, but it goes beautiful.
My box wore out the Band, as they can't be adjusted with regular tools while in the vehicle. This in turn scored the drum. I gave the box number to the local transmission parts suppliers & he told me I had a Patrol. Apparently, the Patrol also shares the same box, but with different gearing. He sold me a 2nd hand drum for $100.
The supplier also told me that about 50% of the torque converters wear out the Clutch & bearing in them, so if you are deciding to do a box, don't skimp by leaving the old convertor in.
It cost me $1400(Aussie dollars) all up as I did the labour myself. This includes the Torque Convertor, Gaskets & Clutches, Synthetic Oil & the Filter just below the battery.
These boxes are SO heavy, it took 2 of us to move it about. I never want to do one again, unless someone else takes it out of the vehicle.
