Let's see everyones engine pics...
danielmcn
Got it in...
nismoplsr
Trimming R32 fan shroud to fit s13 mishimoto.
PSM HMIC, rad, and shroud all mocked/fitted.
Cleaned the block getting prepped to paint.
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
Cheap HG Blew...go figure, this is how my "ENGINE" looks for now...
OEM HG going on Monday morning I'm pretty sure :dblthumb:
Can't start it and get the water/oil mix out completely (already drained it) until my ECU comes back from having my NISTUNE board installed.
I was thinking Zebra Print Valve Covers/Cam Covers...which is it lol kinda both really maybe Zebra print on the Upper Timing Belt Cover/Cam gear cover.
Carl H
:ohno: fram filter? :tisk:
TimTurboZ
I have about 1300 miles on the motor I just did my 1st synthetic oil change, I plan on mobil 1 and and decent filter...tho I never have had an issue with a FRAM and millions of people use them....my friend uses an oil called swepco that he says is good, royal purple seems too expensive. I just don't see the point on a OEM turbo to worry about things that minimal,this is a DD/Track car not a 1/4mile beast
Carl H
cut apart a fram filter and you'll see why it costs 3$.
its not the turbo you have to worry about, its the engine bearings.
RRRRB
Car: 98 RB powered S14
i had broken the oil pump in my honda, gears were broken in like 7 places. It went un noticed for 3 miles, i had attempted to beat on it and it just fell on its face, i was like WTF so just cruised it home, tried 1 more time... same thing, then i finally noticed the oil pressure gauge sitting at 0 psi!! i was pretty much home already... tore the motor apart found the oil pump...
took all the rod bearings a couple mains and cams out to my amazement they all looked great.. so great that i put it all back together with a new oil pump using the same bearings...
the reason for the stumble was the turbo stopping too btw
The point of my rambling is that i was using royal purple for oil... i wont be using anything else
this is also a motor that made over 600whp (all the time) continuesly got raped to 9k RPM etc so i was surprized to say the least
Huriel791
Car: 1990 300zx--Rb20det
1990 300zx - Rb20det, stock internals, 308whp.
Insported
Car: GTR
RRRRB
Insported wrote:Image
Specs please :bigthumb:
Insported
Car: GTR
ART Fuel Rail, EV14 1000cc Injectors, AEM EMS V2, Aeromotive 13101 FPR, Lightweight AN Lines for fuel rail, catch can, oil drain etc, SPEC Twin Disc #001, ART Mod Intake Manifold to single throttle body, ART 10AN Cach Can Setup, Borgwarner FMW S362 Turbo, Greddy 3Row, 1piece Piping Tial Q BOV & Tial MV-R Wastegate, 3.5 Exhaust all the way back. Factory long block for now and that about sums it up.
RRRRB
I like it! how much power does it make?
240drfter
Car: 1990 240sx hatchback rb25det(sold without motor)
1993 vert built rb25det he351cw (for now) in progress
gomer23
Car: 1989 Nissan 240sx
Since my old picture host died, heres the most recent picture I have.
Zacho2
Car: RB25 Nissan Laurel
Supposed to have a 6265, but after a garage break-in I am left with my old turbo.
huafist
What are you guys who are doing top mount turbos doing with your power steering fluid reservoir?
RRRRB
i made a bracket out of 16G sheet stainless steel that fits the resivour, then i bolted it to the front of the cylinder head right behind the upper timing cover..
There is a picture of it mounted on the previous page ( last post on that page)
huafist
RRRRB wrote:i made a bracket out of 16G sheet stainless steel that fits the resivour, then i bolted it to the front of the cylinder head right behind the upper timing cover..
Looks good - I think I have some scrap sheet metal I can use to cut/reweld the stock bracket to relocat it to a position like that.
RRRRB
i didnt weld anything, i just cut and sanded/filed out the spot where the resivour slips into the bracket... just like the OEM one
godzilla_753
I couldnt hold off, here my hunk a junk, Ill be cleaning up the engine bay next so hopefully you guys will get to see a nice before/after lol
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
RB25DET neo with RB26 ITB's?
godzilla_753
OutToWinPAHC wrote:RB25DET neo with RB26 ITB's?
Yezzir, it was a b**** of a job, took me 5 days to swap the whole engine/transmission, took me 5 months to get that crap on there. Of course it woulda helped if I had my own tig welder. RB's are such great sounding engines and those ITB's are so sweet :yesnod
Prof Chaos
Car: 95 mustang 5.0-sold
90 mustang 5.0-needs engine
88 mustang - still project
73 super beetle- Almost sold
99 bmw 323i- DD
90 M30/RB20- das gangsta
holset hx35 FTW
my M30
brock864
Car: rb25 powered s13 coupe
richracing
Car: 280z
DETurbine
Car: Nissan S13 RB25
Here goes a cell phone pic of my current setup:
Will revise when I get some better pictures.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
cell phone pic of my some what cleaned up engine bay.
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
Not quite baller status (yet), she is totally stock.
boostedh23a1
Car: Datsun 240Z
Datsun 280Z
I see 2860-5 twins in your future my son.
elguapo260sx
Car: 96 240sx w/ rb26dett 423hp at 15 psi
gmac708 wrote:Not quite baller status (yet), she is totally stock.
what you need is a confederate flag on your roof.
