Yeah the drain is going to be a lot shorter.placham wrote:Don't know bout that oil drain line on that Holset in last pic, angle and length to drain back is odd. Might be functional but its not ideal,,,,, just my 2cents, I would get hose heat sleeve or fire sleeve their sometimes called and run line between ex runners if u have to, to get nice straight and short drain back. That's what I would do.
kind of makes the intercooler useless if you're trying to cool it with hot air. not to mention the length saved in piping isn't going to make much of a noticeable difference in spool timeTheRBguy wrote:because everything is moved forward, and i wanted quicker spool time and more flow to the radiator.
TheRBguy wrote:considering i knocked off like 4 plus ft of intercooler piping im going to say im safe in saying your wrong.
robbie2883 wrote:kind of makes the intercooler useless if you're trying to cool it with hot air. not to mention the length saved in piping isn't going to make much of a noticeable difference in spool timeTheRBguy wrote:because everything is moved forward, and i wanted quicker spool time and more flow to the radiator.
Nice, Is that a sneaky ls coil conversion in there?OutToWinPAHC wrote:
u may have to do a writeup on the coil setup. it looks so much clearner than the ls ones..OutToWinPAHC wrote:LQ series
