C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Fri Sep 05, 2003 3:14 pm
Are you guys serious? Left-foot braking and heel-toe do not increase lateral grip. Left foot braking is used to provide a quicker smoother transistion between acceleration and braking, then into the turn(trailbraking). But as you get to full lateral load you should be off the brakes, and perhaps only on the gas enough to mainitain speed until you are ready to accelerate out of the turn. If you need to use the brake in the middle of a steady-state turn, then you are doing something wrong. Using the brakes in the middle of a turn will start taking away lateral grip in order to allow for braking. If you try do go beyond the limints of the tire, you'll likely lock up the tire and understeer like crazy.
Heel-toe is just to drop you into a lower gear while you are braking. It also does not provide anymore lateral grip. Heel-toe should not be used while turning. It should be used when you are approaching a turn. For one, a slightly botched heel-toe during full lateral load may cause you to lose grip. Even if you don't spin, and the loss of traction is momentary, you've just scrubbed a couple tenths of a second of your lap time.
By the time I'm fully committed into a turn, my left foot is on the dead pedal pushing down to keep my butt planted in the seat. My concentration is on the road ahead and keeping the car at the limits. My rightfoot is holding the gas to maintain speed and perhaps make throttlesteer adjustments if necessary.
