Cyberkreig wrote:LFB is not a constant or sustained petal pressure, it is a tap, that can not be done with the right foot, because it is busy carefuly setting your corner speed. This tap slows the vehicle only very very slightly, as you have not let off of the throttle, but it does transfer weight forward, increasing available tractoin.
1) If you are at the understeer limit, any braking will make the understeer worse. Your front traction circle is already maxed out, forcing it to provide braking will only take away needed side force required for turning. Weight transfer does not occur until there is actual decceleration, There'll be no decceleration until the tires can provide a braking force. But then the braking force will come at the expense of more understeer....
2) If not at the understeer limit, decceleration and weight transfer will occur per your example. Perhaps LFB under power is more comfortable to you than letting off the gas and tapping the brake (The same amount of weight xfr will occur - it is only dependent on the rate of decceleration)
3) However, since you are on the throttle, note that the amount of rear braking force generated by the rear tires will be countered by the forward torque of the drivetrain. For the tires to generate the same amount of decceleration force as POB (to generate weight xfer), the fronts will work propotionally harder. The result is understeer.
Technical arguements are not bad things. It motivates thinking.
