BuudWeizErr wrote:Heel Gas and Toe Brake is hard if you are tall. I do Heel Brake Toe Gas because I can't get my leg angled the right way under the steering column far enough.
I think I need to figure out how to mount my seat farther back and get a steering wheel spacer, then I will be able to do it.
I'm 6'2"
A little off topic but I am 6 foot tall and have to drive the car with a helmet all the time.
I noticed that I could get full leg extension with my seat all the way back but the wheel was too far away.
My first step was both for security and lengthening. I installed a tekniq removable hub. It has a converter for the momo wheel I use and moved the wheel about an inch closer to my chest.
I instantly fell in love with it.
I recently added a 50mm sparco extender on the column to move it further out. Now all I have to do is add my rollbar and seat and I will be set.
Try the tekniq or an extender. They are really helpful. The only thing that is strange is using the signals. You have to get used to reaching for the stick when you could just slap it before.
I will try and scrounge up some pictures of it for you guys.
