If I were you Gli, I'd keep this thread on topic... "LED tail conversion - preliminary discussion and idea thread" Sure, gather interest but don't start the group buy here.gli liphon wrote:
The initial offering of these will be a group-buy type of thing pending mod approval and all that. I haven't set a firm price yet, but I'm shooting for around what it would cost you to buy a good set of led turns and tails. I'm not listing that price, but go look at what the 3157's run on autolumination or v-leds that have comperable led counts and you can get the idea. I need to wire a few of these up to verify that I can meet that goal and the labor to do it will be as reasonable as I can make it. My goal would be to offer one price for the lights, whether you DIY it or not. So no matter what you choose, it costs $x and its just the additional cost of the new tail lights if you want me to do them for you. Also, this is based on doing the coupe tails, I haven't seen the back of a sedan light to see if its different or weird in some way. I've also had some interest from sedan owners in doing an additional light for the turn as I had drawn up in my original pics. I'm currently planning to just do one fixture for the coupe and you'd just leave your turn empty (I'll give you something to plug in there so it stays water tight). This leaves you set to put your gt-r style overlays on, or completely black out the rest of the tail (wink wink).
I'm glad there is a lot of interest, so lets get the group think going with this topic:
HOW SHOULD THESE BE WIRED?
Give me your ideas of what you think would look best. We're talking coupe only at this point, so everything is in one fixture. Try and format it like I have below so I can keep it all straight.
my current favorite:Headlights off (day mode): everything offHeadlights on (night mode): outer two rings at 50%Brake indicator: everything at 100%turn: outer two rings at 100%, only using half the ring/semicircle/C shape. the semicircle would be matched to the tail, so on the drivers side it would be a C shape, passenger a backwards C
These can really be wired in ANY way you can think of, so as long as you don't want every led to do something different, it can probably be done. If you cant explain it, post a rough picture or email me the pic and I'll post it.
do you return the product once youre done "assuring quality and safety parameters"?LongBeachCoupe wrote:Again, tyler blake or myself will have to have a item in our hands before it is allowed to be sold to you guys to assure quality and safety parameters are covered.
why not just take the whole red lens that's inside that tube out so the LED board is showing? He said hes going to chrome the disc that the LEDs are sitting in, so it wont look bad. and yes i know theres an issue with the fact that there needs to be a reflector, so why not just take that red area in my pic and make it the reflector? just cut out a disc out of a reflector and super glue it on or something......just an idea.brandonbeeb wrote:that centre piece cant be taken out, unless you want to cut into that hole piece which will look weird if theres plastic to the sides then the centre is blank. you cant place it in front because you cant open the headlights like the sedan ones. thats why i went with custom pc boards and made the ring perfect to fit around the blocked out centre on the new boards.
The part will not be returned. But an installation writeup, pictures, and unbiased feedback will be provided to the community before any of the members dollars are put into play.bina12834 wrote:
im sure that little round red lens could be taken or cut out.brandonbeeb wrote:its all one piece inside and me and dangeris are comming up with some new ideas for some sedans and coupes
Well its not the LED wattage I am worried about, and don't take this into offense but if its the resistors and the design. A good design can keep it well below poor design and you could shoot up.gli liphon wrote:that's a good question. based on the leds i'm planning to use, it looks like the total draw of 76 is going to be 4W. No worries on fuses. These will need an inline resistor for the turn signal though, I have a few different ones to test out once one of these is built.
None taken. This is the first time I've tried something like this, so if you know what I should avoid doing or suggestions for what to do to make it work really well, any help would be appreciated.spockrock wrote:
Well it depends what are the technical specs of the LEDs, you need to determine your circuit design, series, parallel, or mixed. So if you are using 12V LEDs then that means all the LEDs need to be in a parallel circuit, means the total current draw is sum of your current draw of each LED. Power is P=VI, Power=Voltage * Current. My best bet is to research as much as you can.gli liphon wrote:
