I've been thinking about this too, and came up with a new idea. Instead of mounting the leds directly in the housing, create cone shaped lenses and mount the LEDs back an inch or two. With the added surface area and reflection, they should shine much brighter and have a neat effect. I've ordered a few different types of LEDs to try out too, some of the standard round ones and some that are flat that have a much wider field of output. The G35 tails are like this a little bit, but I don't think the depth is that much. Here's a drawing with a half inch reflector and a 5mm led. I'm not sure I like this pattern yet, but I wanted to get this out there since you brought it up. Since this is straight on, its just going to look like a bunch of dual cicles, but you'll get the idea. Right now I'm thinking of at least an inch offset, but it could go a little higher since the original depth of the OEM reflector is about 1.75" or so. Its kinda hard to visualize, but hopefully this helps.Mr_Coupe wrote:i think they look great but to me they are so small i could barely tell the difference. couldnt they be slightly bigger like the g35 leds ?or the ones nismo made for the 350z
gli liphon wrote:Thanks for all the comments and suggestions for far, please keep them coming! I finally figured out the math to get these spaced exactly right and all that jazz. The plan right now is to use chrome led mounts and put them into a single piece that ends up with this configuration:
Its a little crazy with 77 total leds, but hey, if you're going to spend the money on new tails, who wants just a few?
Here's some pics of the actual chrome mount with an led in it
Here is a close approximation as to how the ring with 6 leds will look
I've figured out how to do the whole thing with adjusting the brightness, so in this setup we can literally do any combination of 100% bright, 50% bright, and off with the same leds (I guess technically you could do additional levels of brightness, but its going to be complicated enough as it is), so as far as picking a pattern for what turns on with the brake, whats on when the headlights are on and what is on when the turn signal is on is completely customizable. I will probably leave this up to each person so you can do your own thing if you want.
Full brightness
Half brightness
Dont let the pictures fool you either, I had to shoot from the side because these things are crazy bright at either setting and it overwhelms the sensor in the camera. Like frickin' laser beams I tell ya.
Anyway, I'm going to try and make some other examples using this design using these LED holders once I get more parts. I'm running pretty thin on my first batch of supplies.
Some additional details on logistics... (all subject to change, blah blah blah) After talking with Bina, I think the best way to actually do these is to do a tail light swap. I'm going to have to purchase an extra set of tails to do my testing anyway, so I'll have a spare set to use. If you end up wanting to get a set of these, you'll put your order in, I'll make them with my spare set and then send you the modded set. So this really will end up being a drop in mod that you just pull your old tails and plug these in. I'll include the shipping supplies and label to send your unmodded tails back to me, and those will get used in the next set for the next person. So there will be a little bit of a delay between each set, but it'll keep the cost down and you won't have to pay for another set of tails (you can if you would rather do that) and you won't have to worry about not having taillights. Pricing is still TBD, but I'm still standing by my original post that stated this isn't about making money, its all about making my own mod to share with the community. I will be doing these for the coupes as well as 4th gen sedans to start. If the response is good, this could easily be expanded to other altimas, it would just be a matter of getting a set of tails and coming up with a design.
Well there's todays megapost as to the status of things. Again, thanks for all the feedback, comments and ideas so far, please keep them rolling in.
edit - I thought I'd mention the legal boilerplate that is going to have to come with these things. The modded tails are not going to have DOT approval or whatever sign offs are needed to make these street legal so these are for demo/showroom only (wink wink nudge nudge). I need to go pull bluebat's legal blurb he has for his overlays, that summed it up pretty nicely.
I don't care if its not a tutorial, I demand the man gets a custom title!gli liphon wrote:So I realized that all my early attempts might be hard to get an idea of what the finished product would look like, so I wanted to make something that will be exactly like the finished product. This is a small example, I only had 6 of the led holders to use. Hopefully this will give everyone a better idea what i'm trying to do. The final product will be this material, but sanded and painted chrome to match the led mounts. These are also mounted and spaced the same way they will be in the final tail light, its the 6 led ring from the pic at the top of the page.
This is NOT how it will be wired, but this shot shows how each led is sealed and the back finish isn't glossy. Even though you won't see it, this side will probably be primed and painted to give a good clean look.
This is the thickness I'm shooting for, around 1/4 inch. You can also see the led mounts are floated in the fixture for easy access.
Here is a straight on shot with the leds lit up. These are wide angle leds instead of the standard dome type, so they really light up the reflector.
Top shot with the ambient lighting off. These are crazy bright. This is the 100% brightness level.
Now I'm just waiting on more supplies to make the first full sized version.
I haven't really looked at the superflux just because I'm not as familiar with them. It seems like those would definitely need to be board mounted and I'm not sure thats a good way to go unless I just have a custom pcb made and all that. It would definitely be possible, but not something I could do as a single run test. Let me know what you are thinking though, I probably just don't know what you are talking about.brandonbeeb wrote:have you looked into superflux led and boards to make them? what do you figure the cost will be and the time to do a set for everyone on here?
Thanks for the heads up, its already taken care of. LBC and I are working out the details via email.dangeris wrote:Definitely interested as long as the costs is substantial
Gli, Make sure you contact a mod like LBC BEFORE doing anything like offering this to the public. There are rules in place here that were set to protect the Nico community. Like everyone here, we'd like for you to succeed in your endeavor however skirting around the rules and/or trying to get out of them would not be the right course of action to take.
