frapjap wrote:Is wiring in the start button just for the hell of it, or do you want it to have it?
I didn't even know you had a Fusion. What year is it? I drove a newer model one with 10k on it and really didn't enjoy a lot about it, but always had an eye for the older, leaner model.
My favorite cheap rental car right now is the Chevy Cruze. Its turbo and engine match the transmission brilliantly, handles surprisingly well, doesn't have back up camera and other things you don't really need, and the price makes sense for what it is.
I traded my Pathfinder for it in August. It's a 2014 model. So far, I've enjoyed the piss out of it. For my 120+ mile round trip commute, I'm averaging 45 MPG, which is a ton better than the barely 19 I was getting in the Pathfinder.
I want to add the push button because I've always wanted a car with push button start. The tech sheets say that you need to have the luxury and tech package to have it, which I have. The main issue will boil down to the PATS. Kind of how MOD was complaining about PATS on his Lincoln. I haven't had an issue with it, but the whole point of PATS is that it's an anti-theft system, and it can screw a lot up if you start playing with anything PATS related. The current ignition switch has a small PATS receiver around the key slot, and it sends a signal to the BCM and PATS units to let the car know it's okay to start. The switch gets pulled and replaced with a push button on the dash, so I don't know how that will mess with PATS. I do know that a center antenna is located by the cup holders, and there should already be antenna in the door handles. If I have the plug for the center antenna, then I'm golden and the wiring already exists. If I don't, then I'm kind of boned in that regard. It's a factory option, so I'd assume it can be added post sale pretty easily. I haven't seen a whole lot of people who have done it. Probably because it's expensive AF. Gotta buy the switch, the center antenna, and two fobs that need to be programmed. Everything I've read makes it sound like the door handle antenna are already there. At least according to the FSM. But the FSM is kind of poorly written and extremely basic. Nissan does a MUCH better job of laying the electrical systems and how to work with them than Ford does.
I got a decent deal for it. We ended up paying 20,800 for it. I looked up the window sticker, and it retailed originally for 32,000 when it was new for 2014.
