Dattebayo »
https://forums.nicoclub.com/dattebayo-u729.html
Sat Aug 18, 2012 9:16 am
I would, given the chance, burn it if I didn't need it right now. It does get great mileage, even tho it runs like an errant left ballsack.
If I ever pull it apart, it would be if I can find a 4-door B13 shell completely assembled minus motor and pull the motor out of this one and attempt to fix the hoses on the bottom side that I know are causing the issue. Then I would swap over the motor.
Then burn the chassis while pissing on it.
