nissanfreak12 wrote:If you have it at idle my guess is VTC springs. Usually lifters make noise all the time and doesn't change tone or pitch the higher the revs. If MMO doesn't do anything, which you should notice a diff after 20 or so min of driving. If not then I would really look at VTC. Since I had all this fun recently with them the springs and seals will cost roughly 15 dollars. They have the heavy duty spring which are 26 for both. Original one work good. You need to pretty much remove everything like you would doing a timing belt except the crank pulley and the lower cover. The two upper covers, the inlet pipes from the radiator and so on. I would really change the thermostat and the bypass hoses while you are there, especially if they are bulging at all.
When was your timing belt done and by who? This is a great time to do a 120k timing belt which roughly cost 550.00 at conceptzperformance, that comes with everything you need including the springs and seals. This is an area not to go cheap in, trust me. If you do the work yourself, which is not recomended if you really don't have mechanical skill mainly cause the timing issue, you can get it done in a weekend and about 600.00. If you just do the springs and seal, a day and about 50 or so dollars.
honestly I don't know because I have only had the car since last october.
The guy lied about alot of stuff being done to it as well.
So its hard to tell when anything was done at all...
I do know the coil packs and plugs were replaced prior to me buying it!
One of my clips on the front left coil pack is broke.
And I have a z1 aluminum driveshaft which there was 130983059 other things he told me it had that it didn't!
I am going to buy the stuff from z1 on friday and run it then change my oil.
I noticed today the tick had gotten quieter but still noticable!
Lifters can get very expensive and very time consuming since you have to take the timing, valve covers, cams, and preferebly the heads off(makes life easier), at this point you might as well rebuild the engine, at least the heads, which is in the ballpark 1k or more just in parts.
