tmeyer29 »
https://forums.nicoclub.com/tmeyer29-u58719.html
Mon Feb 21, 2011 11:35 am
The very early 90's had the soft valve issue. Any build dates earlier than June 22, 1990 for NA's and December 11, 1989 for TT's had the issue.
quote from tt.net
"This is a known problem with the very early '90+ Z's, both NA and TT.
Somewhere around 350 1990 Z motors were produced with 'soft' intake valves. The chances of having one of these engines is pretty remote. There were 35,000 or so 1990 models sold in the US alone. It took Nissan until mid-1992 to get enough data together to determine what the problem was and to isolate it when it occurred. By then, cars had tens of thousands of miles on them, so it's not a problem that occured in the early stages of ownership. Although Nissan published a Technical Bulletin describing the problem and giving the engine serial numbers affected, not all of the engines in the group will experience the problem.
Other problems could cause these symptoms including a worn spring in the intake valve timing cam. This is also a known problem, which Nissan diagnosed in 1992 also and issued another Technical Bulletin about. This is much more common and could be the problem here. Three things could cause the noise: the VTC tensioner spring, the auto tensioner, or a lifter. Nissan indicates in the Technical Bulletin that the lifter is the primary suspect, followed by the VTC spring and then the tensioner.
Then, just to confuse things, Maximas, which use a different head, have a similar problem that's caused by some other things. I mention this because some folks have confused the Maxima problems with the 300ZX ones because the engines are similar.
The 'soft' valve problem *could* be in NA engines with serial numbers lower than 777599, while TT engines are lower than 619550. The engine serial number is located on the rear of the passenger's side head. Car assembly dates are earlier than June 22, 1990 for NA's and December 11, 1989 for TT's. The intake cam problems are NA ENGINES ONLY, and are for engine serial numbers lower than 475679 in cars with VIN's lower than 012836 for the coupes and 003754 for 2+2's"
