drewusmaximus »
https://forums.nicoclub.com/drewusmaximus-u261880.html
Tue Apr 19, 2016 6:10 am
There was the upper bolt on the intake side, hidden in the back that I didn't see. Removed that, used the hammer claw to pry it off. The head gasket is fine too.
I have TDC in place on the cam and crank shafts. Replaced the cam gear, guides, chain, tensioner and all O rings and seals. I'm now cleaning up the mating surfaces but, what a PITA! It's difficult removing the old silicone. My only concern is the shaft for the distributor and oil pump. I clearly remember the way it was positioned but, it fell out when I pulled off the oil pump. I'm worried the splines on the shaft won't line up with the crankshaft splines. It should line up since the crankshaft hasn't moved at all. Theoretically, I should be able to slide the shaft in the same position it slid out.
Any suggestions before I pop the timing cover back in? I threw on assembly lube on the chain. I blew out the oil passage for the tensioner with carb cleaner. I put locktite on the chain guides bolts. I cleaned the interior and exterior of the timing cover with brake cleaner.
Thanks in advance
