dawm thats what happen to my carBigvinnie wrote:
Just to clarify relative HP to rev range.
A bolt on turbo KA will make 180whp MAX with the stock maf and 270cc injectors. The problem is that peak power won't exceed 6000RPM boosted
NICE!!!!! Chip or daughter board?-RJ- wrote:Im ordering the chip tomorrowmy girlfriend is buying the wideband for me. ha awesome
Chips are for SOHCSDaughterboards and emulators are for DOHCS-RJ- wrote:chip, dont tell me i needed the daughter board
I don't know what you bought? Description is extremely vague to say the least. If its a 40pin header chip it still needs a daughter board.
If any of these ebay sellers told you you would need a daughter board and realized your total net cost would be $80 for chip daughter board and then another $20 for someone to solder the board in place you probably wouldn't buy it. It cost about $100 to get the entire set up, not just the chip. This is why I advise for nistune, or PLMS daughter board chip sets. this is common knowledge in the eccs community.-RJ- wrote:http://shop.ebay.com/merchant/...fromZ
heres it, it doesnt say anything about a daughter board though. Im a little confused now.
When you say feed it to the analog signal, do you mean connect the white wire to the plug that connects to the stock o2 sensor? I have aem uego btwD-UNIT wrote:I cannot stress this enough INVEST IN A WIDE BAND your ecu will love it. Just feed it the analog signal generator and your KA should do things you wouldn't imagine it could do.
kungPOWadobo wrote:yeah this would be a good set up if you were going KA-T but it amazes me how much more power you guys get out of these KAs without turbo with just the maf and injector set up.
