my coworker (ex con) said if you shoot up a cap full of whiskey, it F's you up! so just stab him with a needle lolFrank E Bones wrote:You got that right dude, we definitely gotta do that someday. Well get Razi drunk one way or anotherspooled240 wrote:hahaha nice frank, i got smashed as well on sat night. We gotta do round 2 w/ nico peeps and more alcohol![]()
i think someone is gonna have to give razi a "special" glass of coke
I think Razi is "special" enough alreadyspooled240 wrote:hahaha nice frank, i got smashed as well on sat night. We gotta do round 2 w/ nico peeps and more alcohol![]()
Thanx man. The trick is catching em while there youngWDRacing wrote:spooled240 wrote:FEBs, your wifeunit is pretty hot. Good job
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AITWDRacing wrote:The T2 is ok if it's a GT2870 or something...to small otherwise.
T3/TO4E in a .48AR hotside ftw Chris.
That dude is probably good over 300, but it's going to depend on the tune and how much timing is pulled out etc. The best way to use a smaller turbo is to get a IAT sensor and cockpit gauge to monitor the temps. If it starts to get really hot you'll want to lower the boost. Or run alky/water injection and just turn the boost up until it drops off because the compressor can't support the volume. Then run a few psi less so as not to grenade the turbo. Since it'll be spinning at like a billion + - 2 hundred rpmspooled240 wrote:^chris look at this turbo mayne V V
what do you think about this turbo? I think it's a garrett "super 60" I think it would support over 250hp though, i'm thinking more like 350hp at 15psi on a KA
what caught my attention was the tighter turbine and compressor housing which should be perfect for a low/moderate boost street KA-T setup I already asked the guy and he said the CHRA is dry so no oil lines and the turbine housing is the standard ford style 5 bolt
When it comes to cooler, I'm all about the "bigger is better" theory. You can get a trans cooler out of the junkyard for cheap cheap, say off of any old GM truck/blazer. Adding any cooler at all inline will be a good thing. If you're willing to do that, you should really look into making the entire underhood area more efficient. You can probably pick up another 25whp by insulating and cooling. Anyone can keep adding fuel and boost, but it not many people make gobs of power unless they're running 15+ psi. I'd like to make over 300 and keep the boost at 10 psi.Razi wrote:Wow that's cheap compared to a new S15 turbo.
WD, I'm thinking about putting a cooler on my turbo's water feed line.
What size and type of cooler do you recommend?
that's what i thought, I shouldve pulled up the volumetric efficiency graphWDRacing wrote:
Cool.WDRacing wrote:When it comes to cooler, I'm all about the "bigger is better" theory. You can get a trans cooler out of the junkyard for cheap cheap, say off of any old GM truck/blazer. Adding any cooler at all inline will be a good thing. If you're willing to do that, you should really look into making the entire underhood area more efficient. You can probably pick up another 25whp by insulating and cooling. Anyone can keep adding fuel and boost, but it not many people make gobs of power unless they're running 15+ psi. I'd like to make over 300 and keep the boost at 10 psi.Razi wrote:Wow that's cheap compared to a new S15 turbo.
Grammar fail.Razi wrote:
I'll try the get the biggest I can find.
That's what she said.Razi wrote:
I'll try to get the biggest I can find.
Tryin ta call my woman butch looking foo!?WDRacing wrote:Yeah good luck with THAT one homie...she looks like she can hold her own.
