ShouldaHadaV8 wrote: i just couldnt get it to stop draining the battery.
if this is only happening with the battery hooked up, there is no way your wiring is correct. if you have a short to ground, or even like a low resistance path that drains the battery overnight, any number of things could be screwing up.
your car needs to have a 12V source and it needs a solid ground an anything thats making them even close to being the same point electrically is going to cause problems. I'd look at your harness, find where it's been modified, then check wiring schematics, and if you can find any discrepancies.
realistically I don't think you can even check things like the maf if that's going on, I don't see how they could give accurate readings even if they're perfectly fine.
