ka24de swap idles like crap. cant drive needs help( pros only)
ryanwrx
Car: 06 wrx tr
s13 hatch
Dude, earlier in the post you talked smack about my comment suggesting bad gas. Now you tell us all you have 2 year old gas in the tank with good gas on top? The pump sucks gas from the bottom of the tank which common sense should tell you its sucking 2 year old gas into the fuel rail. Drain the gas out, refill and enjoy your new engine.
ShouldaHadaV8
Car: 92 hatchback 240sx, j30 diff, TIEN tie-rods
ryanwrx wrote:Something easily overlooked, try to spray some starting fluid in the intake. Sounds like you may have bad gas
nope already checked again .... the tank was under 1/8 tank and i put in $20 worth of 93 3 months ago. do the math yourself its not the fuel. I WOULD LOVE FOR IT TO BE THAT EASY :chuckle:
And the ECU read 34. maybe I need a new knock sensor or it could just be bogging to bad, maybe i have bad wiring or a bad ECU. But I dont think it the gas itself.... and remember im having to jump my fuel pump relay with speaker wire. it didn't do that before. when i press the gas peddle it bogs , unless it ease on it then it revs fine untill i give to much too fast and it bogs again. more like either an A/F mix problem( egr is deleted only vacuum is from the mani to the fpr, it has all new fuel lines) Bad timing could be it I dont own a timing light/ gun.
but the whole car is just my toy so i dont let it upset me, i got the car and title for a set of rims and bought the motor for $200.......lol
I will figure it out soon. but thanks for trolling
NISMO24096
Hey man I shoud be at my parents house thurs nite. and more than likely again on monday nite...so if you see my car come on by and introduce yourself....we can look over the car some...
driftgodleo
Car: '89 two-tone s13
well i dont know if this has anything to do with it, but using an OBDI harness with an OBDII motor might have caused the problem.
thomasjamal
Car: 93 coupe
I know this sounds like a really simple and dumb answer, but make sure you actually clean off all the grounds.
I spent a week trying to figure out why my KA wouldn't start and why it had a crappy idle when I push started it. I was just about to buy some parts when I decided to unbolt every ground, clean them, scrub them down with sand paper and scrub the spot they bolted to and then hooked them back up. As soon as I did it my car ran perfectly.
This was also right after I swapped out one KA for a better one and I hadn't had the problem before. So give it a try if you haven't.
ShouldaHadaV8
yeah I already tried that. im getting no resistance 0 ohms. im gonna try going back over the basics and make sure timing IS right
benarovi561
Car: 92 black hatch
ShouldaHadaV8 wrote:yeah I already tried that. im getting no resistance 0 ohms. im gonna try going back over the basics and make sure timing IS right
i acutally just swapped my s14 96 ka into my 92 s13 lol. i changed the dizzy, upper intake mani. thats it. i had the same problem. ran like s*** and didnt idle for s***. so fixed all vaccum leaks, fixed alot. seems that the return line on my fuel rail was clogged. check that. and bro you know the s14 maf is compleatly different than the s13 ka maf right? u need the maf and pigtail. im in that situation right now. good luck.
ShouldaHadaV8
The only vacuum I have is from the intake mani to the fpr. I removed the egr crap. im using the original wiring harness and all the s13 parts. I also have all new fuel lines. I need to get more voltmeter readings and post
ShouldaHadaV8
NISMO24096 ran a consult cable on my car :bowrofl:
we noticed everytime you hit the gas the ignition timing drops really far.
we tried swapping out MAF sensors it didn't change the outcome.
if anyone has any advice>>>> let me hear it
benarovi561
Car: 92 black hatch
ShouldaHadaV8 wrote:NISMO24096 ran a consult cable on my car :bowrofl:
im in the same situatuin as u still man. still havnt found anything.... when you give it more than quarter throttle gas does it want to bog and stuff? its wierd..
ShouldaHadaV8
NISMO24096 brought by a #29 ECU to test.
it fixed the relay problem ( i now can put in a working relay and it functions properly ) ,so i know that my #28 is messing up, But it still drops ignition timing when I press the gas so now i can rule out the the relays circuit is not causing the problem.
More tests coming.
NISMO24096
Glad I could help you out man. sorry I didnt get a chance to come back over and help you test the Maf sensor again.. but maybe if I get back over there we can...good luck man and dont give up...
ls1240
Car: 1990 240sx hatch
hey man i bet your distributer is your problem my idle was like crap when my dist was 180 degrees off check that if you havent already hope it helped i didnt rread the whole thread hahaha i was to lazy to
