KA24de Power pulley sets! First development! NicoClub Special price!
stillracing
Car: '91 240sx SE, 2000 Integra GSR, 2005 Evo 8 MR, 87 RX-7 TurboII
pr240sx wrote:How much reduction will cause the pulleys?
IE ASP does 30% on the AC, 15% in the water pump, etc)
I'm aiming for.
Crank - 0% reduction - more rotational stability to assist in dampering/balancing.P/s - 15%alt - 15%water - 15%
So 15% across, for most efficiency of the pumps but no cavitation in the water pump, and no excessive pressures from the p/s pump to blow lines out, etc. As well as no large loss across the alternator either.
Hope that helps.
BackIntoAnS13
Car: 92 s13 hatch
Put me down for a set Also by chance are these going to be offered in different colors??? Are we going to have to put anything down??? If so it wouldnt be a problem i just dont see you going into production and then having people flake on you.
Dlauth
Car: 1995 240sx SE Concord Gray
I was wondering what shipping is to Collinsville Illinois 62234. Also I was wondering if they will be in differant colors. Thanks
stillracing
wantaRHD180sx wrote:Put me down for a set Also by chance are these going to be offered in different colors??? Are we going to have to put anything down??? If so it wouldnt be a problem i just dont see you going into production and then having people flake on you.
The pieces are going to be offered in the polished aluminum finish, not currently planning on anodizing yet. Though this isn't set in stone yet either.
I will also have pics up in the next couple of days. Tech issues are making it lag.
stillracing
Dlauth wrote:I was wondering what shipping is to Collinsville Illinois 62234. Also I was wondering if they will be in differant colors. Thanks
about 13.25 USD through ups.com (apx package size)
and see the last post for the colors...
tigwebu
Car: 1993 Nissan 240SX Convertible
Would you sell alternator, powersteering, and water pump? How much?
racin-type
Car: cars
I think the reason Unorthodox underdrives the crank is to get the max weight loss where it counts. I think my stock crank pulley was like 6.5lbs or so. Unorthodox Racing's crank pulley weights in at 1lbs 9.2oz. Did you say yours was gonna weight around 3lbs?!
So you are underdriving the accessories? That means they will be bigger in size correct? Won't that weight increase just offset the weight loss from your crank?
Also have you done testing of the underdriven alternator's percentage (15%) to see what voltage the charging system will be at, at idle? And since you're underdriving your accessories pulleys, that means people that already have Unorthodox cranks can't use your accessories if they only wanted those, because it would be super underdrive their belt system.
Can you explain more about this "rotational stability to assist in dampering/balancing?. Whats dampering? And couldn't the pulleys be balanced no matter the size?
You still haven't posted a picture of some type of aluminum cnc'd product to show your machine work.
Thanks, I am really interested in your set but would like more info.
stillracing
racin-type wrote:I think the reason Unorthodox underdrives the crank is to get the max weight loss where it counts. I think my stock crank pulley was like 6.5lbs or so. Unorthodox Racing's crank pulley weights in at 1lbs 9.2oz. Did you say yours was gonna weight around 3lbs?!
You CAN underdrive the crank pulley, however doing so removes minimal mass, you CAN remove the same if not more mass from a stock diameter as well. however, when you underdrive the power side (crank pulley) the diameter gets smaller and that is it.It has nothing to do with mass...but some companies that make dampers ( harmonic balancers/crank pulley) say that there is crankshaft vibrations that the damper compensates for, that lightweight crankshaft pulleys can't compensate for. This IS TRUE, however in our race experience we have seen no problems associated with the pulley sets.By NOT underdriving the crankshaft pulley there is more mass towards the outside circumference of the pulley(like a tightrope walker with the long extending pole to assist in a easier/ more accurate balancing.Doing so allows for less wiggle/vibrations in the crankshaft pulley, inturn it takes away from the vibrations of the crankshaft so it will make it easier on the crankshaft.
Pulleys can be balanced in any way shape or form, however, with the statement above on dampering...By placing weight as far away from the rotational center of the pulley it allows for more balancing WITHOUT more mass added. Honestly this is a problem/situation that all manufacturers of lightweight pulley sets DO NOT consider, hence the harmonic balancer industry hates on pulley sets.
We are pioneers in anything that we do here at STiLL RACiNG, just wait until you hear of some of the other stuff in the works! It'll blow your mind.
As for the pics....They will be up by wednesday, our prototypes are still on their way to us, and they are sending me on a trip to NYC for biz. So I'll be posting again by wednesday.
Also with the prior statement of dampering....By underdriving the accessories, it adds diameter to the pulley, not neccessarily adding weight. Its all in how you engineer the part... And because there will be no real weight added it WON'T compensate out for crankshaft weight loss. It will be a straight across the board loss of rotational mass with good balancing/dampering still.
And this is being sold as a set, so I would suggest selling the crank pulley if you want a set, but some people might want to super-underdrive their system anyways...
As for the alternator, I set a good number on that one, we have an electronics engineer here too, and basically we have shot for a good balance.
As for the 3 lb statement...I had stated that as a HIGHEND approximation. It will be much lighter than that.
I hope this answers your question.
bone_stock_240
Car: 1995 Infiniti Q45
Hmmm. Overall mass isn't really the concern though right? If you want something to have less rotational inertia than wouldn't it be best for it to have most of it's mass as close as possible to the centre of rotation? I don't know what the tradeoff between having lower inertia vs higher damping is and which is more desired for performance or drivability/longevity. Just figure the more questions you answer, the more comfortable people will feel about getting into this sweet deal.
law
Car: 96 240sx
add me in
stillracing
bone_stock_240 wrote:Hmmm. Overall mass isn't really the concern though right? If you want something to have less rotational inertia than wouldn't it be best for it to have most of it's mass as close as possible to the centre of rotation? I don't know what the tradeoff between having lower inertia vs higher damping is and which is more desired for performance or drivability/longevity. Just figure the more questions you answer, the more comfortable people will feel about getting into this sweet deal.
Overall mass is a concern for power, however placement of the weight is not going to affect power but to the max of about 1/8 - 1/4 of one horsepower. It is the answer to not adding weight, simply have the weight that it has (lightened as much as it may be) work better to the advantage of dampening without sacrificing horsepower.
Most companies disregard dampening factors in their design, figuring that it doesn't matter, and the only way to add dampening is to add weight, so they dont.
Harmonic Damper companies do the opposite, and add weight and manipulate its position to add dampening effects to the crank pulley.
We simply factor all of this into our designs, so that you get the best of both worlds. Not to say that this would be better than using a harmonic balancer, for dampening effects but its going to be alot better than other pulley sets I have seen for any type of car.
And there is a small bit of tradeoff, but only a fraction of one horsepower basically.
And we're all for letting you guys know as much as you feel you need before pursuing...
Have a good one.
HKSdrift3r
Add me to the list! email is [email protected] so whenever you guys are ready for shipment let me know. I am in 07751. Any estimated date when these will be done? Awesome deal btw!
George
George
tre614
Car: 2001 nissan frontier xe
Would those pulleys fit the ka24de in a 01 frontier?
crash n burn
Car: '91 Nissan LE hatch
'93 Nissan Silvia UDSM
'92 Infiniti M30
add me in
they come in blue?
chenpo
Car: 1997 nissan 240sx
stillracing wrote:Hey guys,I work at STiLL RACiNG and we are looking to do a power pulley set for the ka24de motor.
The price would be a special introductory price of $250 a set, and would include the crank pulley, alternator, powersteering, and water pump.
am i still too laye i want some of that hit me up my email [email protected]
silvia240sxguy
Car: 95 nissan 240sx s14
i would like a set put me on the list
stillracing
tre614 wrote:Would those pulleys fit the ka24de in a 01 frontier?
Yes they would. I added you in case you were interested..there are only a couple of spots left.
If you dont want them..I'll simply take you off the list.
stillracing
Jung918 wrote:Would it be possible to just purchase the alternator and water pump pulley?
Not currently. sorry.
stillracing
crash n’ burn wrote:add me in
they come in blue?
No colors yet, but as I said before..its not set in stone. Once the prototypes are done being tested, then we'll give the go for sales, and at that time we will consider the costs for anodizing. But the $250 special price was for polished aluminum.
We'll keep you informed.
240sxRAOR
Car: Nissan 240sx Convertable 1992
I would like in on it too because soon I will be building an all motor and am going to need every bit. Also it looks realy good when all the pulleys are stylish not just one.
chenpo
u guys have it it any pics or any sign of the pulleys ..?
stillracing
chenpo wrote:u guys have it it any pics or any sign of the pulleys ..?
The first signs. =)
First proto piece in. Looks good and fits like designed. All is a go!
Exact to spec. The others will be as well.
I will post more pics as they come in...
anthony_S14
I was wondering if the crank pulley will have identical timing marks like an oem crank pulley
chenpo
wow looks kool nice cooler
stillracing
anthony_S14 wrote:I was wondering if the crank pulley will have identical timing marks like an oem crank pulley
but of course.
anthony_S14
was wondering if the email has gone out yet... I haven't received one yet
BackIntoAnS13
Car: 92 s13 hatch
[QUOTE=anthony_S14]was wondering if the email has gone out yet... I haven't received one yet[/QUOTE
Me neither
HKSdrift3r
^ditto! Pulley is lookin very nice though..
George
stillracing
EndlessDefault wrote:i'm intrested please post pics, i need a pulley set
I dont have your email. I need it. I am sending the emails tonight.
Ohh yeah and here's the crankshoft pulley. sorry for the delay.
f1altima
Car: 1996 altima 5spd
I have a 96 altima a(ka24de) and was wondering if the powersteering pulley will fit, this is the only pulley i would like to purchase so would it be possible to buy just this?
