aleph1 »
https://forums.nicoclub.com/aleph1-u177.html
Sun Oct 26, 2003 12:19 am
Those turbo specs seem about right, cept id want a 50 trim compressor wheel..or is that a/r? I forget. Also, at least 360degree thrust bearing, possibly thermal coating on turbine. Anyway...500 is a lil low for a nice turbo, I dont want some cheap crap, Id figure 700 for a decent one with options I listed above.
The main reason I think its good is that it will all match up, as the manifold and downpipe are the most pain in the *** parts to get (IMHO) for a turbo kit, as some dont match and such. SO! The whole "barebones" kit idea can really be the same thing as if you designed the a manifold and downpipe for the most popular turbo for KAT people, which would have to be a T3/T04E. You dont NEED to throw in a turbo and wastegate, I would just want a manifold/dp setup that will fit correctly on an S13 with a T3/T04E.
What we REALLY need is a FMIC kit for KA-Ts. Im sorry, but 900 or so for one through Nsport is unreasonable, they know they are about your only option short of making your own pipes, not everyone can afford a welder, so ya.
You should...borrow..orions setup. Buy a bunch of Greddy VSPL SR20 kits, and just make a hot pipe for it (S13 at least). While the S14 will need the S13 cold pipe. EH?Or you could just make the hotpipe that would be compatable with the VSPL kit, which the customer can buy seperately. OR you could just get some cheap cores or full intercoolers and make your own piping, but the greddy thing would be easier, yet prolly more expensive.
