Anyway, I looked at the Bullydog manual once again and I can see why I skipped through this part since it was closer to the end of the manual and this thing is pretty generic in covering a broad array of vehicles;
Also, I did some searching and found this thread dealing with WOT;Wide Open Throttle Disable (WOT)
Wide open throttle refers to a throttle position governor placed on stock Nissan vehicles. It limits the driver from using 100% of the vehicle throttle from 0-40mph. Bully Dog's Wide Open Throttle feature will remove this governor from the vehicle.
WARNING: using this vehicle option is at the risk of the vehicle owner.
Bully Dog recommends that this feature be used for drag racing purposes only and should only be used on a designated drag race vehicle on a sanctioned drag racing track. Removing Wide Open Throttle will place added stress on the drive train components, Bully Dog will not be held responsible for damages incurred as a result of the use of this feature.
post4981627.html?hilit=wot#p4981627
All of this is making me think this is not exactly related to the CVT persay but all Nissan vehicles and that the CVT is limiting throttle separately and can't be controlled by turning WOT on. I just wish I had a little more knowledge on the issue to begin with.
And I just read through the thread again. Unsure if you have a 6MT or CVT?
