CursedGTR »
https://forums.nicoclub.com/cursedgtr-u31163.html
Sun May 28, 2006 2:48 am
Just figured I would post up an update on this thing.
Continued working on the motor today. All I have left to do really is put the valve covers on (waiting for paint to be finished), finish painting the throttles (nothing more than spacers now) and do some other stuff here and there. This Weekend I painted the motor mounts, intake manifold, Cam Position Sensor Bracket, Altenator Bracket, Cam Gear Backing, installed the cam gears, set timing and installed the timing belt, Torqued the head down, welded in 1/4 NPT female bungs for use with AN fittings on the valve covers and put on the ATI Damper Pulley with the lower belt shroud (painted in blue ghost flames, which will be about the way the valve covers will be). I also blocked off the water passage under the intake manifold (do not really need it anymore) and started to replace as many bolts as possible with Hex Bolts. We also cleaned the corrossion off of the exhaust manifolds by using a sand blaster with fine sand and a scratchy pad with metal polish, the results were pretty nice looking. All the pictures are below. Hope you likey.
Blocked off water passage for intake manifold underside
Engine as it sits now
