soooooooo...how to install an engine from the bottom of a car:
step 1: attach new clutch, crossmember and steering rack:
step 2: lower engine onto creeper (or other rolling thing) and move under car:
note: be sure to get thumbs up of approval
step 3: once engine is under car, lower entire car over engine and bolt in crossmember, then, using a jack, lift the car by front bumper support and support with jackstands. move jack under crossmember and lift engine/crossmember up so you can finish bolting it in.
Final product:
YUP! engines in guys. just one quick note, if i had to do it again id be sure to REMOVE the power steering pump. its a major PITA working around it and the tension rod support points. either way, got the engine in with minor casualties to the paint. some quick touchups and its all better.
next up on my list: new fuel lines, new fuel filter, new oil filter, add oil, power steering pump mod (no more hicas) and work on finding some DOHC KA power steering lines (anyone know of any for sale?)
