updates!
so after i got all the rear taken apart, i decided it was time to pull the subframe/diff. diff needed to get welded, and i wanted to pull the subframe...well just cuz. anyways that turned into a nightmare. the front passenger side bushing on the subframe was seized to the stud that comes down from the unibody. after a lot of propane torching and prying i got the subframe out, leaving the bushing behind. at this point i decided to get solid aluminum bushings for the rear (no still havent got them, but will be ordered shortly-ish).
some before pics of the subframe and diff:
after pics will be up when its all ready to go back in. i've got some plans.
anyways, this is the bushing that was such a PITA:
at that point i had already burned/scraped/peeled all the rubber off in hopes that the propane torch could help me pull it off. no luck, so i went and purchased a MAPP gas torch, hammer, and chisel. after much grinding, torching, chiseling, hammering, cursing etc. (we all know how it is working on old cars) this is the result:
i will be sanding down the rust, re-threading all the studs, and buying new nuts for the rear subframe, all in hopes that i will never have this issue again. some never seize will also be applied to the bolts, again for preventative measures.
second update, got my self some new used axles
with the one broken seal that the last axle had i just went and picked up a set locally for $80
not bad if i say so myself.
also got my front hubs in and installed (cuz installing them is so hard lol)
theyre the ichiba front hubs. probably the easiest way to swap to 5 lug in the front
also, with the hubs in, and my front suspension put together, i borrowed a wheel from a friend just to "test fit" and see where the suspension was sitting. i didnt have lugs and the wheel was rubbing the coil spring, so i didnt set the car down, but all up in the air it sits pretty "low". theres maybe 3.5-4 inches between the fender well arch and the top of the tire:
shes gonna be loowwwwwww when i get to set it down
i'll be picking up some spacers (probably 10mm or so) when i get my wheels to help clear the coils and push the wheels out a bit to fill up the fenders. in the future i'll have my work wheels and they should fill the fenders without any spacers
annnnddd last but not least, for the ebrake, theres this piece:
does anyone know how to disconnect the two ebrake lines from it? i've tried, and if it really is only a matter of rotating the cable and pushing it out, then i need to man up and do it. if not, any pointers are appreciated
