diamondj30 »
https://forums.nicoclub.com/diamondj30-u656.html
Thu Jun 10, 2004 1:19 pm
i mentioned were you can get sway bars,ive havnt used the same spring maker as others here for there j's..mine sre donelocal 40 % over.2.25 front drop---1.50 rear,raked,level on tires..coilspring spesialties online somewhere,can do the spring,but lighter ive heard,cpouple others here have done it.i use koni yellows for an i30 in front.cut bumpstop 1 inch to clear that,they are inserts,rear struts,made to my specs,double adjustable at the top,no jackin it up.rear struts 1250.00 to have made by koni for my application.does that help.the front konis work cause im low enough,they are for a 96,been so long i forget.anything else while were at it,lol..if you can have ,or get a coilover supplier for these fine peeps i bet some would bite..alot of peeps want to mod there j's,but aftermarket is next to nill compared to other casrs.my cars heavier than the norm i use pretty heavy springs ,tight but smooth ,can drive for days,have..tight enough for no way go lower sidewall.not with sz50's...my 200sx with 17 inch 40series side wall feals like mud in a turn compared to mine.kumhos
