j30 suspension question
diamondj30
Car: Not to low , not to high , just right .
cant you backstrap the tweet in the door floating it and agling it where you want it to point.should work.i can run tweets in door and keep a tight stage.buy the way,every dorr i did cut down on noise driving.very step i took there was a difference.alot of well just noise comes thru the door.mine is over the top..cause i dont work and have plenty of time for tearing things up.im one of those who thinks a 40k car should be half quite.loud *** cars.a judge tried to mark me of for spearker whine one time and i should him it was the fuel pump,man.amagine how loud they are exposed to the inner cabin.my car shares the pump noise with q's cause its so quite,thats what charlie was tell me at infiniti of kirkland.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
j30 leopard wrote: it is a loud fuel pump.
Loud fuel pump = failing fuel pump.
diamondj30
not hear,you dont understand my car is quite,fuel pump makes noise.all do if they dont there not working..might be working ok i get 25 miles a gallon with 436 gears,common..perfectly working is loud to me.to each his own.id hate to think my fuel pumps been bad for 7 years,wow
