I would look into Diesel rated non synthetics, they have good ZDDP levels, so you wont need to add any break in additives.slik_s13 wrote:thanks for the reasoning indeed! non-synthetic it is.
Yah, after reading that I did a lot of digging, I discovered some pretty nasty stuff. I have the article saved if you want to read it.Hijacker wrote:Agreed. There was a thread in 240 gen about the new ASC certified oils coming out that are diong some nasty things to brand new motors.
AgreedHijacker wrote:The hot rod part sounds like a conspiracy theory to me.
I haven't heard anything about ZDDP levels effecting gas mileage. The API stated reason is, during combustion, some ZDDP does escape the crankcase and enter the exhaust gases, this increases emissions, and also adversely effects catalytic converters. Due to the rising cost of Platinum OEMs are making catalytic converters out of other materials. Over extended periods of time ZDDP will break down conventional catalysts, and it has the same effect on the newly designed catalysts, but at a much faster rate.Hijacker wrote:The reason for the lowered ZDDP levels, as I heard it, was to increase gas mileage and reduce emissions for newer motors. What I would like to see is for the oil companies to put out a ZDDP additive that can be added for older motors to stop the negative impact.
Redline and royal purple aren't API certified since they retained the higher ZDDP levels. After reading the posted article, you could buy oils rated for 4 cycle motorcycles or diesel motors. I'm still trying to search to see if there's a straight up additive that can add back the missing ZDDP levels that doesn't cost 12 bucks.homeslicej2 wrote:What oils (other than Mobil 1 extended performance) have higher ZDDP levels?
Bingo! Most people (including the shop that did my swap) Pull out their inner fender liners and the undertray piece b/t the bumper cover and the rad. support. Running a FMIC (esp. a bar and plate) reduces the airflow to the rad anyway, but with that piece missing, a lot of air slips under the rad and never hits it, causing overheating/running hot. Mine will stay under 200 in the upper rad hose on hot, humid GA summer days, as long as it stays off the freeway. When I'm on the freeway (3k+ RPM's) it will get up to 225 and I cut the heat on. I don't the A/C hooked up, but the condenser is still in place bc I plan on hooking up before summer. I'm going to put on the Altima fans and fab an underpiece like these guys did http://home.satx.rr.com/nissan...t.htm and hope that fixes the issue.SideWays=smiles wrote:I think part of the reason many people have cooling issues, may have somthing to do with airflow.
You should have seen the engine bay before we hit it with the pressure washer. I pulled the fender liners out back in October when I swapped the siilvia front end on and hadn't put them back on because I thought the car may have gone to paint and body around new years. Now it's been pushed back to March/April, and I'm too lazy to put the liners back in since they have to come back out for the tear down for the shop. Road salt makes for a dirty engine bay.SideWays=smiles wrote:Ive been running my stock S14 radiator for 4 years now, although I do have an oil cooler. Ive had the car on the road course with no over heating issues, I only ever turn my fan on when Im stuck in traffic or while Im letting the turbo cool. I think part of the reason many people have cooling issues, may have somthing to do with airflow.
Your engine bay looks a lot like mine, a little dirt never hurt anybody, function over form.
Wow, Ive never seen my water or oil temp above 200, even on 100 + degree days. I do have all the plasic pieces though, I run a tube and fin IC, and my AC is all gone.homeslicej2 wrote:Bingo! Most people (including the shop that did my swap) Pull out their inner fender liners and the undertray piece b/t the bumper cover and the rad. support. Running a FMIC (esp. a bar and plate) reduces the airflow to the rad anyway, but with that piece missing, a lot of air slips under the rad and never hits it, causing overheating/running hot. Mine will stay under 200 in the upper rad hose on hot, humid GA summer days, as long as it stays off the freeway. When I'm on the freeway (3k+ RPM's) it will get up to 225 and I cut the heat on. I don't the A/C hooked up, but the condenser is still in place bc I plan on hooking up before summer. I'm going to put on the Altima fans and fab an underpiece like these guys did http://home.satx.rr.com/nissan...t.htm and hope that fixes the issue.
