That was a demonstration for bleeding the lifter.Slipstream wrote:What were you placing in the lifter? Purpose?
Hijacker wrote:Notable upgrades:Cosworth 1.1mm headgasketMahle 86.5mm pistonsFidanza lightened flywheelExedy Stage 1 clutch (same as what I've been running on my old motor)
I prime my pumps by stuffing them with either vasoline or grease. You want a petroleum based product that will dissolve into the oil, but is thick enough to stay in the pump to help give it suction on initial startup. Then to help really get it primed, we crank it without spark plugs (less load on the engine) to help get the pump to circulate the oil before we crank it over for real.slik_s13 wrote:i heard of some peeps that primed there oil pumps before their intial start. did you do this also?post up an engine bay shot if possible. for kicks..
During break in, there needs to be some wear on the bearings and sleeves, they seat in to each other, and there are often some metal shavings in the pan at the first oil change. Synthetic oil does its job too well, it does not allow that initial wear to happen. Dino oil also helps the piston rings seat properly. I use specialized break in oil additive whenever I rebuild a motor. I used to use normal dino oil for break in, but due to the reduction in ZDDP in all API certified oils I feel the extra security is worth it.slik_s13 wrote:whats your reasoning for going with a non-synthetic engine oil for the break in proccess. i was thinking of using castrol 10w30 syntech for mine. but im not too sure whats the best for a freshly rebuilt motor.
