Introduction - The Black Sheep
BlackRC3
Car: 1990 Nissan Fairlady
Alright well first off my names Kael from Winnipeg, Manitoba, i purchased a 1990 Nissan Fairlady in June 05 from a good friend of mine who imports JDM vehicles. It came with 109,xxx km's in amazing condition.
Some shots after her first full detail (took 9 hours)
It came with a few mods such as H&R lowering springs, 17" BBS 3 piece wheels, Nismo shift nob, Nismo steering wheel, AB Flug full cat-back, Pop charger, Stillen Front bumper and sideskirts(at least that's what i've matched them to be, correct me if i'm wrong), HKS dual stage boost controller and turbo timer.
So i had some fun with it for a few months, took it to the track and ran a 13.77@101MPH with a 2.1 60ft (pretty respectable for a rather stock car) and this was on stock boost as far as i knew since the boost controller was never hooked up correctly and later removed all together since the ecu was stock.
Then i started my new job and the mods started flowing. Alpine type r components, alpine 4channel digital amp, Sony 7" widescreen on the dash with a pioneer dvd/mp3/cd player in the lower din. Then it needed some security so i decided to go with a Loaded Avanguard system, threw in some relays to control the windows, turn the stereo on, and a few other things all by remote.
OK, it was a blast until.... i lost to 3 turbo civics, and pretty badly i might add.Now for some power! Took the car to a friend's place who's dad is a master welder and has done some amazing work on cars in the past. Went there to get a FMIC put on...and well... things got a little crazy....
Here's a few pics....
Doesn't quite look like what you would expect to see under the hood of a 300zx does it.
So at this point i was flat broke and needed to re-group for 6 months to decide where i wanted to go next, did a little work on the car at home cleaning parts up
well after leaving home in April 06 it was off to Walls Rod and Custom, home of the 1900WHP Twin Turbo 76 Camero running 7.16 in the 1/4 (street trim).
Decided to go with FJO as a stand-alone to control the one-of-a-kind setup.
some pics from the shop. (taken by my phone, forgot the camera :P)
The work is almost done, i've probably spent 100hours at the shop helping out the guys, since no one has really done a 300zx quite like this before.
but it's getting late here in freezing winnipeg so i'll leave you guys with the mod list. Feel free to comment, and i'll do a little writeup as to how everything will hopefully work.
work done:-removed: all wiring, all lines, all rear steering lines, all wiring under/inside dash, p/s line setup, emission controls-rewired headlight circuit, flashers, 4 ways-rewired 90% of the under dash components to work with the FJO system and to bypass old ecu wiring-wired in and installed water meth injection-removed engine/transmission/exhaust to weld in 2 probes for egt then re-installed mot/tra/exh-mounted egt control box, map, FJO 341b2-cut out stock wiring harness, reloom stock harness, lay in 341b2 harness and cut to proper length (soldering all connections)-tuck and loom stock harness in the rad cradle-setup boost control solenoid-setup FJO afr wideband-removed all unnessary items from front and rear fender wells for emissions-relocate factory fuel return line-remove all rear steering factory circuitry-remove/install p/s, custom make new bracket-retrofit jdm n/a p/s pump-remove and relocate stereo for new gauges-removed all a/c evaporator setup under dash-removed and re-wired complete dash piece-install 341b2 wiring harness to use factory fuse panel and setup harness for all boxes-R&D for cam and crank angle sensors on the front of the motor-remove and install complete turbo setup for bung install
Parts =D :-Garage Biitz 3.5"-4.25"-2X3" Exhaust-Garage Biitz Front Mount Intercooler 24X12X3-Garage Biitz Pie Cut Chargepipes-Garage Biitz Turbo Headers-Garage Biitz Oil Lines-Garage Biitz Catch Can-Garage Biitz Full Race Rad-Turbonetics T66 Ball Bearing Turbo-SARD 800cc Injectors-Ogura Twin Plate Clutch-Ogura Lightened Flywheel-AC Delco Plugs-HKS SSQV Blow off valve-Tial Wastegate-high flow rad fan-JDM p/s pump-FJO 341b2-FJO crank sensor-FJO cam sensor-FJO crank target wheel-FJO harness for coil packs-FJO wideband harness-FJO fluid temp sensor-FJO 4 port boost control valve-FJO water injection install kit-FJO water injection nozzle-FJO water injection fittings for duel nozzles-FJO water injection filter-FJO water injection pump and relay set-FJO 6cyl coil pack-FJO Probe K-type-FJO Probe box-Wideband sensor NTK-FJO wiring harness-FJO 200psi water meth sensor-FJO 100psi oil pressure sensor-FJO fuel pressor sensor-FJO air intake sensor-FJO 4bar map sensor-FJO coolant temp sensor-FJO boost gauge ultra light-Magna mechanical fuel pump (good to 800hp)-Aeromotive fuel pressure regulator-Custom braided fuel lines
Suspension Mods:H&R Lowering SpringsKoni Yellow ShocksDiesel Camber kit Front and rearDC Sports Front Upper Strut BarEndless Brake PadsAEM Cross drilled Rotors Front and RearGoodridge Stainless Steen Brake LinesHICAS 4ws system removedWalls Custom* Hicas BarWalls Custom* Rear Tie Rods
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
WOW!? just looking at the pic's made my knuckles bleed, and that black paint looks like it's about to just run off, absolutely gorgeous
Black_93_300ZX
Car: 1993 Nissan 300ZX Twin Turbo, 1987 Nissan 300ZX Turbo
Always wanted to see a nice single turbo conversion for the Z, well done, be sure to post dyno sheets once it's over with.
BlackRC3
well basically i've built everything but the engine itself for 700whp. so next summer i doubt i'll try and push more than 450whp just to keep things safe but i'll definately keep you guys updated
Black_93_300ZX
Edited by moderator
If you don't like it. Play elsewhere.
phanatikz32
Car: 1991 NA to TT z32 biatch!
on a more positive note your paintjob is fresh, im thinking about painting mine black, hope it turns out like yours.
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Welcome to NICO!
That's an amazing looking Z32 you've got there. Quite a bit of custom work, time, and fabrication into that bad boy. Hats off to you. I'm definitely interested in seeing more pictures and info as it comes along.
Good to have you as a member
Zinister
Car: 1991 Nissan 300ZX Twin Turbo and 1990 Nissan 300ZX N/A
Welcome! Your Z looks stunning! I cant wait to hear more on the single turbo conversion on your car! Keep us updated!
whiterps13
Car: white LE hatch
Damn, those pie-cut welds are amazing. Definately got some work into that thing.
I cant wait to see some dyno numbers on race gas. That thing is going to be a BEAST.
XcreatureX
Car: 96 240sx SE
Thats hot!
Seth
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
Welcome to Nico, awesome Z32!
BOOMSHAKALAKA
That Z32 is nice...
Welcome to NICO
Logan76
Car: Junk
Gorgous Z32.
NSR240sxe
Car: '97 Kouki S14, '98 Sentra SE
Welcome to NICO
Hot Z!! I love those wheels and the paint is amazing. Keep up the good work
WidebodyZ
Car: X300 LWB Vanden Plas / W203 C240 Luxury Sedan
Somehow this looks familiar, but I can't quite put my finger on it. My kind of work though.
NSR_s30
'71 Datsun 240Z
I have a question with everything done to the car, why run AC Delco plugs in it and not something like NGK R's or Denso...etc? Just wondering.
BlackRC3
those were the plugs that i had put in before i started this huge project, i've yet to even think about plugs yet but what would you guys suggest?
evildky
06 Nissan 350Z GT
I believe Denso or NGK platimuns are standard replaements, I am running Iridiums, I just got a wild hair, prolly just a waste of money
NSR_s30
'71 Datsun 240Z
NGK's.
nsrZ32
78 Datsun 280Z
01 Ford Focus S2
NSR_S13 wrote:NGK's.
NGK's are the only way to go for the Z32. Run the colder NGK platinums.
PyroTheGreen
Car: 1990 300zx N/A
I like this setup a lot. I've kinda been itching to do something similar, with a centrifugal supercharger for boost. How hard was the fab work for the intake piping? How did you split the intake for two throttle bodies? I can't tell where you did it from the pictures.
OriginalWheelman
Car: '15 Ford Focus Electric
Your welds make me jealous.
JDMZ32
Car: 1991 Nissan 300ZX NA slicktop 5spd red
wow that's definitely awesome. i'm looking forward to updates on this one! and i'm 99% sure that's not a stillen front, unless it's really old and i've never seen it or something . since your FMIC is so huge, i think you should get the greddy front. so, you went to get a fmic installed and you ended up with a custom single turbo setup?! whoa haha.
Sgt
Car: 1991 Fairlady Z (JDM) Twin Turbo
Man that is awesome. Nice work!
I live in Saskatoon. If you are ever over here, let me know, I would love to see your Z in person. I doubt those pictures do it justice.
Also what is the make of that front fascia?
tg
Your fabricator definitely knows his stuff
Great job and nice car!
300freekzx
Car: 1990 300zx N/A, 1992 Honda Accord LX , 1991 Honda Accord LX, 2006 M35 Sport
sweet
Re037
Car: 1992 300zx 2+2 NA
very nice!
those anybody know the model of those bbs wheels?
has anybody noticed this thread is also 3 years old?
JDMZ32
Re037 wrote:has anybody noticed this thread is also 3 years old?
dammit! i saw 11-13, but didn't take note of the year, so i thought it was only a coupe months! now i feel stupid and disappointed because i'll probably never see and update on this awesome car.
P.S. i also noticed that he joined NICO in '06, and i wondered why it took so long for him to post this stuff. me...
naladude911
Car: 2001 Infiniti QX4
ZOMG!!! my grandparents live in Winnipeg, God, I wish the U.S would step up and let us import JDM vehicles easier. Nice Z
BlackRC3
3 Years and still goin, i'll bring you guys up to speed....
-It dyno'd 420whp and 391wtq on a mustang dyno (stock block/stock heads) @15psi
-ran 13.55@111MPH (clutch gave out in 3rd so i coasted part of the way) also a 2.1 60ft
-The motor finally gave out on me during a friendly race against a buddies r6 (blew cyl #6 rings)
-Called CZP and ordered a few goodies: -JWT VTC Springs -Ferrera Dual Heavy Duty Valve Springs w/ Titanium Retainers -Wiseco Coated Pistons 87.5mm -Eagle Connecting Rods -Engine Gasket Repair Kit Plus w/ Cometic Head Gaskets -New Nissan Oil/Water Pumps -New Nissan Bearings
-Rebuilt the motor, bored 20 over, 3 angle valve job, balanced and blueprinted
-Started to install the new motor and ordered some last minute goodies: -CZP 58mm Throttle bodies -SS Clutch line -Southbend Stage 5 DXD Clutch (good to 690tq) -RPS CYN-R-G Billet Aluminum Flywheel -CZP Chromoly Clutch Pivot Ball -Inland Empire 300zx Heavy Duty 1-piece Driveshaft -Brembo slotted 12.75inch Rotors in the front w/Hawk HPS pads -Brembo slotted stock rotors in the rear w/Hawk HPS pads -SS Brake lines F+R -Motul Racing Brake Fluid
So as of today the motor will is scheduled to be dropped in this saturday
*I think your right, i doubt it's a stillen front bumper, i'm not too sure if i'm gonna keep it or put a different one on this summer before she hits the paint booth (was keyed outside my house in september 08')
*Rims are 17" 3-piece BBS RS's in 8.5 and 9.5 (looking to sell actually)
*when i get a chance i'll take a picture of where the split is for the dual throttleboddies (it's right after the ic outlet leaving the intercooler behind the rad
