That's exactly what we did with both upper and lower plenums, just used the gasket to outline what we could remove. Same idea with the heads when they were ported240six wrote:The semi-rough of the surface on the intake track is beneficial to the higher air flow. Gasket matching will yield better results than smoothing out the surface. When you gasket match, make sure you leave 1mm all around beyond the gasket edge. Actually, making sure the opening on the lower plenum is just as big or slightly bigger than the top will be best.
yea i know i realized after cause the jack point was flattened out from previous jacking so i couldnt see where it went exactly i know exactly where it goes now240six wrote:Jacks on the TC rods?
I wanted to do this at one point, but, I would thought this would cause premature wear - maybe not...
Ugh, it seems like its always something with these cars. How's the oil pressure?BlackRC3 wrote:Well it looks like the dyno is further away than i thought....
can anyone pick out what the hell this noise is? vtc gear? lifter? piston slap?
http://www.youtube.com/watch?v=bRNNCDgt3xo
it completely disappears once the car reaches operating temp...
BlackRC3 wrote:Well it looks my myself and just about everyone else was wrong, it WAS the intake cam gears, lifters are perfectly fine!
here's a video right after we started the car with the new gears in
http://www.youtube.com/watch?v=0cBAoVR9Go0
FINALLY no more lost sleep! now we just gotta put it back together and off to the dyno!!
Probably not the right thread for this but I found one on ebay, needs repaired but any competent glasser can fix this very easily. It's a little overpriced but then again you won't find many like it.Sgt wrote:That bumper is probably some Japanese kit that never saw the light of the US market. I have only seen a pic of one car with the same front bumper as me. I only ever found out the make of it after taking it off and minding the make inscribed on the inside. It is a "TBO" bumper on my Z.
