BlackRC3 »
https://forums.nicoclub.com/blackrc3-u50605.html
Sun Aug 02, 2009 5:56 pm
indeed! she made 572whp @ 28psi on 91 pump gas!! The tune was good for the dyno but not for the street, motor didn't last long
2 hard runs on the highway after a 4 hour dyno session and the heads started to lift off the block due to some serious detonation. Lost compression in one cylinder and started to burn coolant.
tore the heads off and found this:
The head was dropped off and i'm picking it up monday, should be another week and i'll throw it all back together and back to the dyno with the PROPER octane gas, C116! so i can drop the boost and lean out the a/f's since i had to run super fat after 5krpm's...almost 10's
should make 650-700whp on c116 for the track. then just gonna run 500whp on the street
