Intake manifold
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
DrewH
Car: 2006 Altima SE R
2012 G37X
I had forgotten that I had already posted it. You installed the spacers right? Check your coolant bypass.
VQpwrdSE-R
Car: 2005 Code Red Nissan Altima SE-R
2013 Nissan Altima SV
DrewH wrote:Check your coolant bypass.
Is this a common problem when doing the spacers?
06SE-R
Car: 2006 Altima SE-R
DrewH wrote: You installed the spacers right? Check your coolant bypass.
going to check it now
06SE-R
Okay, so don't flame me too hard but I'm not 100% positive of what I'm looking for exactly. I checked all the hoses again and everything is tight.
Come to think of it I don't recall doing a coolant bypass.. :bash:
DrewH
2012 G37X
VQpwrdSE-R wrote:[Is this a common problem when doing the spacers?
No but its the only part of the coolant system that was touched and its not hard to imagine it not being on far or tight enough.
Another spot to check is the coolant line that goes from the oil cooler/warmer sandwich plate to the radiator.
DrewH
2012 G37X
06SE-R
I did NOT install the bypass which I will take care of shortly. The leak is up front on the passenger side :gotme
This is probably a re re question, but am I suppose to plug the holes after connecting these two hoses together? The instructions don't say
DrewH
2012 G37X
As I said, check the coolant line from the oil warmer/cooler. Its very cheaply made and is known to fail.
06SE-R
DrewH wrote:As I said, check the coolant line from the oil warmer/cooler. Its very cheaply made and is known to fail.
will do
DrewH
2012 G37X
06SE-R wrote:This is probably a re re question, but am I suppose to plug the holes after connecting these two hoses together? The instructions don't say
You can plug them if you like but unless you plan to ever use them again I wouldn't worry about it.
06SE-R
Installed the bypass( still can't believe I forgot to do that) and I checked the bottom coolant hose again. I can't tell if that's where it's leaking from or if that's where it is falling down to. :mad:
06SE-R
I've driven the car to work for 2 days now and I can't smell coolant or see any. I'm not sure what's going on I might be going crazy.. I'll keep an eye on it though.
VQpwrdSE-R
Have the car ready for the meet at Carlisle?
Return to “3rd Generation Altima Sedan (2002-2006)”
