this is the most common issue around injectors..the rubber grommet or seal at the manifold..as for the leaking injectors..the only way to know for shure if you have this issue..is to unbolt the rail..lay it somewhere on the motor where you can see it....turn the key to prime the fuel system...if you even get a drop or a small spray..replace the injector...next test...crank the car over ..again with rail removed...after you stop cranking..if you notice a small dribble of fuel on one of the injectors..replace it...the MAF meters the air and adjust the fuel mixture..so any extra..any at all..can have effects on the engine...allso..lack there of fuel..can have the worse effect..detonation and permanant damage....good luck and please..keep us all posted on the issue.locoluna825 wrote:only thing different form you guys is i got my injectors to stop leaking fuel, they all check out fine with the resistance and voltage coming from computer is fine, and my car runs awesome besides the stumbling idle and injector leak code im getting from the engine light. im waiting fora manifold to injector seal set and im going to replace those if it doesn't work im taking it somewhere to be fixed so i can flame them if they dont fix it
not quite getting this test, I understand that the MAF meters air and dump fuel accordingly, but if the rail is disconnected it should still squirt fuel as if everything is normal because the air coming in from the intake manifold (where the rail sits in) is unmetered air so the MAF can't adjust to it.liquid_cool wrote:next test...crank the car over ..again with rail removed...after you stop cranking..if you notice a small dribble of fuel on one of the injectors..replace it...the MAF meters the air and adjust the fuel mixture..so any extra..any at all..can have effects on the engine...allso..lack there of fuel..can have the worse effect..detonation and permanant damage....good luck and please..keep us all posted on the issue.
The idea is to get fuel pressure into the rail to check for leaks on the injectors. The car doesn't need to run to do this, just be KOEO. That aside, this is a retarded test, to be honest. Most rails have a tiny, tiny clip holding the injector to the rail as it is supposed to be bolted in place. If those clips were meant to hold that injector in at pressure the rail would probably be clipped in rather than bolted. That method of testing is a great way to break those clips and shoot injectors off the rail like little bottle rockets. I think the OP already experienced this actually. The proper method usually involves an engine steth, you can hear them leaking under pressure.s13_maJiK wrote:
I understand the KOEO test, the 2nd test listed above doesn't make sense to me. Crank it over and see if it sprays fuel? Its going to, it just doesn't seem like a relevant test.del82 wrote:
OP, if you're using OBDII it should have seperate codes for a leak and an electrical fault, fyi. Have you actually replaced the injectors yet? Don't buy used injectors, and don't replace one at a time. You may fix the leak, but the motor won't run right for quite awhile.
(EDIT: Saw that it was a '91. Ignore the OBDII part, but diagnosis isn't any different.)
it depends on which wire your talking about. if your talking about a wire that pulses (signal to injector for example), a very small amount of voltage will be dropped across the test light, prob not enough to effect the injector.gingerbredman wrote:*just throwing this out there, but what would happen if you poked an ignition wire with a test light (while system/motor is running?) random thawt, just curious..
ka24 side fed injectors are not clipped in dude...they are in there own cradle, and the rail can be removed to test..allso..an ohm test only test if the electronic componet's of the injector are working..not if it is stuck open and dumping fuel...you can do this same fast and easy test with topfed injectors allso..using utility wire to hold them in place...i dont sugest fast test that dont work for what there intended....the info is good sire.and helpfull to those whithout a bay full of specialty tools at there disposal.del82 wrote:
