float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Nov 19, 2003 7:15 am
Zushi-did you lengthen the MAFS wires? If so, check the continuity from the ecu to the plug. every wire should have continuity through it, if not, you have a wire thats not connected. As for the Tach I'm assuming you have an 89/90. If so you'll either need to get a tach from a 91-93 w/o HUD (or w/HUD if ur car has it) or get a JDM gauge cluster. I was lucky enough to get the cluster w/my swap, so I just pulled the JDM tach out and put it in my USDM cluster. So my mileage is still right and I have a 9G tach, yea!
