boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Wed Nov 19, 2003 7:15 am
Could be blown, but I also do the RWD cars as well and can definitely say that there is a white wire on yours for the AFM, but you need to find where it was cut from which probably inside the harness somewhere. Take some pics of what you got and let me see. The color codes between the FWD and RWD are nott o different except for some of the external pieces, but the rest are the same such as the CAS, AFM and power transistor. I still think your car is not wired correctly or your ecu wouldn't have been blown. I see too many guys on the forum with electrical problems and most of them stem from the way the ecu was manipulated via afc, vpc's, etc by the previous owner. And when the car was scrapped, the owner removed the devices and left the wires cut, leaving the new owner not a clue as to who's what.
