Ignition Coil Relay
NeedCAforS13
Car: CA swapped S13 coupe
exactly the same:)
Sean
Zushi
Hey, you know how I said that even without my keys in, my lights would be on...well I wanted to see if I had a short in my wires or if it was just my ECU(seeing as how I blew it and all......heh). so what I noticed was that if i just plug my battery in and go to ACC or anything but trying to turn the car over my lights dont come on. After I turn the key and try to start it, my lights come on and wont go off, unless i either unplug the battery or the ECU. P.S. I blew the ignition on switch signal pin in my ECU. Could it be that when I send a pulse to that ignition on switch pin that it kicks on my lights? Confused.....must get help. heh.
boost_boy
Your car is not grounded prperly, either! Please make sure you ground the engine block to the chasis and the head to the chasis.
Zushi
Hey, i checked my engine for grounds and I got em. My throttle body is grounded, along with my head and block. is there supposed to be a certain resistance to it though or anything? let me know
Zushi
Hey, I checked my spark plugs for spark(by just turning over the engine and looking for spark) and i had none. however, on my second cylinder(2nd from front) when i was looking for spark and holding the coil pack I got shocked a bit. I thought that perhaps it jumped to the block and got me but...still no spark. bad ground? remember though, my ECU pin was blown(but i resoldered back very very nicely). hrmmmmmmm..ideas?
s13sr20chris
what method did you use to check for spark?
Zushi
i took off the coil pack and then put a spark plug in the red rubber fitting and looked to see if the spark plug sparked.
s13sr20chris
did you touch the threads against a ground?
Zushi
oh, no.... should i?
s13sr20chris
yeah, in order for the spark to jump it must have a path to ground home slice. power from the coil, jump the plug gap, through the threads to ground. try it like that bro. its an easy mistake.
float_6969
This one time, at post whore camp...
Zushi
Lol...what about the people who reply to everything i put out.....heh
