Scott McLellan »
https://forums.nicoclub.com/scott-mclellan-u3074.html
Thu Dec 04, 2003 5:10 pm
Let me start a list of what I would do and reasons:
1) Ram Air- Your car is moving, so why not use it to your advantage? Just please don't waste your $ on a boost gauge;)2)Mass Air mod- Cobra? Of course put a nice intake setup on (would a custom setup on the pass. side w/ battery relocated be better since shorter?)3)Bored tb- more air4)Ported intake- not some kid w/ a dremel. A pro w/ a flowbench and some experience. Porting can decrease power if you don't know what you're doing.5)Ported head- see above6)Race valves- smaller stem and heat coated to reduce det. less weight, better airflow. Possibly oversized slightly7)3 angle valve job- increased flow at low lift8)Perf. springs and titanium retainers- higher revving stability and for bigger cam9)Cams- going radical? expect it not to have any street manners.10)ARP fasteners thruout- increased strength11)Crank- I personally think that factory forged doesn't sound bad so I would stick with that and yes stock stroke. If you are going to rev higher you need all the journal material you've got, right?12)Titanium rods- as strong as steel but lighter for less recip. mass- I found a set that run approx. $2400- yeah or $600 ish for some nice steel ones that weigh a little more13)Forged Pistons w/ total seal rings- I'd say 10.5 for street on pump gas. Lighter weight again reduces recip. mass for higher rpm stability. 14)Header/highflow cat/exhaust- better air flow. maybe get one of those valves so you can have an open exhaust when you want it15)Ignition- MSD/external high output coil/plug wires/iridium plugs16)Grounds- better perf. of all elect. components17)Underdrive pulleys- also has anyone ever done a dry sump or elect. water pump? Might be dumb, though. Maybe remove A/C system and conv. to manual steering18)Cooling system- alluminum rad. so that cooling doesn't take as much draw from alternator for an elect. fan conversion. I'm not sure if you would even want a lower temp thermo. for power?19)Custom crank scaper/louvered oil pan- reduce power robbing windage20)ECM tuning- takes all mods into account21)Lightweight flywheel and driveshaft- less recip. mass22)Synthetic fluids throughout- less friction=more power23)Fuel system- the "right pump", high flow rail, injectors, good filter, and maybe fuel cooler and/or insulate fuel lines24)If your just running a 1/4 mile or for a short time, the "bag of ice" on the intake manifold before the run has been proven to be worth a tenth of a sec. or something like that25)Balance rotating assembly- higher revving engine and smoother everything26)Blueprint- cause it sounds good. No just to make sure everything is in spec and "tight" for precision's reliability factor
Here are a few things I've heard will help:1)Cryro-treat engine and components2)Heat coat pistons on top and coat sides with anti-friction coating(I think it's teflon if I remember right-Speed Pro makes them I think)?3)When boring engine, bore w/ a torque plate and, here is a crazy one to think about, with the engine block @200 degrees F. Yeah, it's been proven that this will make a very small amount of power but hey...
----OR----
Coates Engineering $15,000 Rotary valve setup- hey you said a KA block means it is a KA and this new "cylinder head" will allow you to run 14:1 (or higher-can't remember exact) compression on pump gas, have a 14,000 rpm redline or limited to recip. assembly. If I remember right, a Lincoln V8 engine put out something like 475 hp compared to the stock 220 hp. That's over double, yeah in a 4.6 L engine (I am assuming). Anyways, for 15K they outfit it for your spec. engine and you won't have to spend a dime on cams, valve springs, retainers, porting, valves, ect.
If all else fails, a little laughing gas. Just kidding.
FEEL FREE TO ADD/FIX THIS!
