trpower7 wrote:Yes, my terminology was backwards. Continueing:
Nissan says .040 maximum overbore. Period. You want to go higher, be my guest, but don't whine when it busts into a water passage or you crack a block in two.
Show me these cars, and dyno sheets, and tell me technical specifications on who decided to make a stroker crank for you and the ludicrous amounts it cost. You think you can push an engine with a bore out to the limit you suggest and a ridiculous stroke like you suggest and expect it to not implode? You overrev the sucker once and you're looking at piston speed I don't even like to think about.
Most people who try to extract more than 100hp per naturally aspirated litre are looking at very large bore short stroke engines (IE, S2000 engine). These rely on a high redline to be able to achieve maximum power, also at the cost of a torque loss. The KA is plainly not that. The people that have extricated THE MOST proven NA horsepower on a KA have done it with an 11.0 to 1 ish compression ratio, stock stroke, and individual carburated throttle bodies. They got about 240whp. Also keep in mind, that no street driven 240 has this setup as far as any of our knowledge goes. It's insanely expensive and doesn't yield itself to any real street use. You can maybe get 200rwhp on a high compression setup with every bolt on imagineable, an ECU retune, and some fine dyno tuning. Maybe. Very few have been able to. You want to not deal with a turbo and the hassles you get there.? Go get an N20 setup. 100-shot and you are right at your power goals.
I really hate to be rude, but please do not post uneducated things and speak them like the truth. This does not help people that are reading the boards to learn. I will not comment on what I said again, because there is no need.
honestly, do you beleive what you say is true? if so you have a lot to learn about the ka and engines in general.
I hope you dont feel the need to comment any further, because this thread is full of your wasted posts already.
